midnitemill
#1 Posted : Friday, January 16, 2009 7:10:45 PM(UTC)
midnitemill
Cycle won't start, all lites lite up, options lites all work, but push start & hold for 3 sec. no start. So must be door latch not latching ??? To make this short I broke the door latch too.
Does anyone know if I can download repair manual that can help me out but most of all, tricks to trouble shooting.
P.S. Still in hot water with wife, need to try and fix asp before water gets any hotter.
libertyappl
#2 Posted : Saturday, January 17, 2009 7:21:43 AM(UTC)
libertyappl
This is a Whirlpool Duet, manual but it should help. Your model was made by Whirlpool.
Nat
File Attachment(s):
Duet Job Aid.pdf (1,508kb) downloaded 12 time(s).
midnitemill
#3 Posted : Wednesday, January 21, 2009 6:35:18 PM(UTC)
midnitemill
Got new door switch, installed, ran the diagnostic test, test went through
C:00 to C:08 with no problems after done clean lite went on. Found out
my delicate botton does not work ( push it lite does not go on)
Tech sheet said to check touch-pad/LED assembly Need help on checking
Guest (5)
Washer cycle won't start, motor just buzzes (Washer Repair)
by Guest 4/6/2023 4:46:53 PM(UTC)
Dryer cycle won't start (Dryer Repair)
by Dennis H 2/6/2014 1:31:03 PM(UTC)
Cycle won't start (Dishwasher Repair)
by scphelping 7/29/2012 10:24:42 AM(UTC)
Cycle won't start (Washer Repair)
by cowher 6/3/2012 4:10:31 AM(UTC)
Wash Cycle Won't Start (Dishwasher Repair)
by gvel 1/28/2011 2:47:37 PM(UTC)
Frigidaire spin cycle won't start without help starting it (Washer Repair)
by abc1234 2/5/2010 10:18:39 AM(UTC)
frigidaire stacked washer dryer, rinse cycle won't start (Washer Repair)
by bigjohnstanton 11/12/2009 12:10:10 PM(UTC)
