Dennis H
#1 Posted : Thursday, February 6, 2014 1:31:03 PM(UTC)
Dennis H
Dryer ran perfectly, put in a new load. Turned knob to select cycle and hit start button. Nothing. It sounds like the timer ticking. I turned the knob to different cycles. Just ticking noise. I held a little tension on the knob to select cycle. It ran for a couple minutes while I held tension on the knob. As soon as I let go it stopped running and will not run again.
fairbank56
#2 Posted : Thursday, February 6, 2014 3:33:59 PM(UTC)
fairbank56
Groups: Expert
Unplug dryer, open control panel and check connections on back of timer. Make sure they are clean and tight. If no problem found there, replace timer.
Whirlpool 3406725 Timer - AppliancePartsPros.com
Eric
