12 Pages«<7891011>»
#81 Posted : Wednesday, October 26, 2011 10:19:08 AM(UTC)
Hi Michael,
Here are the breakdown diagrams and Replacement parts for JENN-AIR JEC9536ADS SURFACE UNIT- ELE | AppliancePartsPros.com
Here is the wiring diagram.
You have to check the switch in both, on & off, positions.
PAPAERICK
#82 Posted : Saturday, November 12, 2011 6:59:05 PM(UTC)
PAPAERICK
i have an G.E. Dryer model dde5900ralwh.4 cycle, but can't dry the clothes.run a normal cycle.but no heat. i check the rear heater elements it should be 19.0 ohms....and the one thermostat front of the cabinet show 00.4 ohms...the other in back show too 00.4 ohms.but i don't now what is the range to know if are good or bad. and have another with this numbers L310-100f and show 00.6 ohms in the scale of 200ohms im my multimeter..can somebody help me to fix this i am car mechanic.im trying fix me dryer too. im appreciate any help,thanks
#83 Posted : Monday, November 14, 2011 12:50:36 PM(UTC)
Remove the terminal block cover on the back of the dryer. Measure the voltage between the Black & White and Red & White wires at the terminal block. The normal reading should be about 120 VAC. Then measure the voltage between the Black & Red wires. The reading should be about 240 VAC. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric DDE5900RAL Electric dryer | AppliancePartsPros.com
salsaman
#84 Posted : Thursday, November 17, 2011 7:48:32 AM(UTC)
salsaman
pretty much but would like to find thread that shows me how to follow the problem
Raul Campos
#85 Posted : Thursday, February 2, 2012 5:49:33 PM(UTC)
Raul Campos
:confused:hello someone could help me pls. I got a kitchen aid refrigerator that ice maker is working properly but It is not dispensing water neither ice.around two years ago somebody did work on the wires that are placed under the freezer door I checked them up they look well attached but I don't how many volts are suppose to come out from these wires ,
Raul Campos
#86 Posted : Friday, February 3, 2012 2:30:24 AM(UTC)
Raul Campos
#87 Posted : Friday, February 3, 2012 4:19:26 PM(UTC)
Hi Raul,
Would like to suggest, you start your own thread in the Refrigerator Repair section, using Post New Topic. Do not forget to post the complete model number of the refrigerator.
People will then see it is someone with a problem.
This should increase your odds of getting a relevant reply.
huxleyn
#88 Posted : Saturday, May 19, 2012 5:42:59 AM(UTC)
huxleyn
Yes. Very.
Huxleyn
huxleyn
#89 Posted : Saturday, May 19, 2012 5:45:29 AM(UTC)
huxleyn
Yes. Very.
Huxleyn
jbarbero
#90 Posted : Friday, June 8, 2012 11:18:20 AM(UTC)
jbarbero
Do these ohm tests apply to the damper control on my fridge?
Frigidaire model # Frs23bh6cs0
Another forum member is pointing me in the direction of a new damper control part # 241600902. I would like to test it just to make sure it really is the problem.
Guest (20)
12 Pages«<7891011>»
