dgloor
#1 Posted : Sunday, January 4, 2009 12:42:00 PM(UTC)
dgloor
A friend has an ice maker that is not working at all. It is not filling with water. She wants me to replace it, but I'm afraid if I do it still will not fill. Does anyone have a suggestion as to what is really wrong with it. If the ice maker replacement comes with a water valve that could be wrong I guess that may cover the problem, but if not I'm not so sure. Since it's a through the door unit, without tearing the whole thing apart I have no idea what plumbing is in it.
Thanks in advance for any help.
#2 Posted : Monday, January 5, 2009 12:20:55 PM(UTC)
How old is the water filter?
dgloor
#3 Posted : Tuesday, January 6, 2009 3:24:36 PM(UTC)
dgloor
2-3 years. but with it removed the ice maker still does not fill.
#4 Posted : Tuesday, January 6, 2009 9:22:48 PM(UTC)
The water filter usually does not last more than a year. If the water filter has been removed then you have to install a special bypass plug. Otherwise the water flow would be interrupted.
dgloor
#5 Posted : Wednesday, January 14, 2009 3:08:03 PM(UTC)
dgloor
the water in the door still works, and the filter cover itself says that the water will still flow with the filter removed.
#6 Posted : Friday, January 16, 2009 12:53:47 PM(UTC)
Remove the ice bin and the ice maker and check the water feeding tube into the ice maker for a frost inside.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
