bx610
#1 Posted : Monday, November 5, 2007 9:05:57 AM(UTC)
bx610
Returning problem.. About every 3months refrigerator stops working... refrigerator temp go up. After being unplugged for a day, works another couple months. There is no ice build up in the freezer.... ran diag on system .. all passed. Air flow to refrigerator compartment has decreased, evaporator fan works. Not sure what to check next. Any suggestions?
#2 Posted : Monday, November 5, 2007 1:05:43 PM(UTC)
Hi bx610
I need you to describe as much as possible what is going on when it "stops".
#3 Posted : Tuesday, November 6, 2007 1:30:21 AM(UTC)
When it fails, pull the freezer back cover off and check coils for heavy frost. If ok, verify both freezer and back condensing fan are working.
If ok, remove control pc board at the back of the unit and check for a loose solder connection at the relays.
Whirlpool Refrigerator not cold enough (Refrigerator & Freezer Repair)
by bsmcc 3/22/2016 6:52:44 AM(UTC)
Frigidaire Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by wing471 9/7/2015 5:42:56 AM(UTC)
refrigerator not cold (Refrigerator & Freezer Repair)
by mick baker 8/24/2015 3:13:50 AM(UTC)
Freezer cold but not freezing, refrigerator not cold enough (Refrigerator & Freezer Repair)
by tyltea1st@charter.net 6/5/2014 6:06:36 AM(UTC)
by mansoura 11/26/2013 5:28:11 AM(UTC)
Freezer & Refrigerator not cold enough (Refrigerator & Freezer Repair)
by HFrank 5/30/2013 10:53:56 AM(UTC)
Refrigerator not cold, freezer fine (Refrigerator & Freezer Repair)
by SteveDB 5/22/2013 10:53:19 AM(UTC)
Freezer icing over/ refrigerator not cold (Refrigerator & Freezer Repair)
by Cheryl W 4/11/2013 5:14:43 PM(UTC)
Whirlpool refrigerator not cold (Refrigerator & Freezer Repair)
by -Ronin- 3/8/2013 5:37:40 AM(UTC)
Freezer and Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by mahplane 8/29/2012 9:11:03 PM(UTC)
Whirlpool Refrigerator not cold (Refrigerator & Freezer Repair)
by medemers 7/29/2012 8:43:09 AM(UTC)
Please Help...Freezer/Refrigerator Not Cold.... (Refrigerator & Freezer Repair)
by SolomonMan 3/26/2012 1:53:14 PM(UTC)
by molly1212 3/18/2012 8:55:27 AM(UTC)
Refrigerator Not Cold (Refrigerator & Freezer Repair)
by stantaylor7 2/10/2012 5:57:09 PM(UTC)
by tonlam 12/1/2011 11:03:11 AM(UTC)
