swalczak
#1 Posted : Wednesday, September 21, 2011 5:43:18 AM(UTC)
swalczak
I have a GE electric range/oven, and the oven will not shut off. The lower burner will stay on. I have to shut the breaker off at the electric panel. The range is around 8 to 10 years old. Is the temperature dial switch bad? What should I check first?
Thanks, Steve.
#2 Posted : Wednesday, September 21, 2011 6:21:25 AM(UTC)
Replacement parts for General Electric JBP65GS1WH Electric range | AppliancePartsPros.com
If the element is on full then odds are that there is a problem with the control board (Item 16 in Section 1).
Probably the contacts on the bake relay are welded together.
Could also be that the board is keeping the relay energized when it should be off.
GE Oven Won't Shut Off (Oven Repair (including Ranges and Cooktops))
by Tracy0407 1/5/2013 4:38:06 PM(UTC)
Kitchenaid KESC307HWH6 - oven won't shut off (Oven Repair (including Ranges and Cooktops))
by perpetualapprentice 3/24/2012 9:05:38 AM(UTC)
KitchenAid oven won't shut off (Oven Repair (including Ranges and Cooktops))
by Norman G. 2/21/2011 4:06:59 PM(UTC)
Oven won't shut off! (Oven Repair (including Ranges and Cooktops))
by mikeamondo 12/2/2010 5:02:49 PM(UTC)
Oven won't shut off & goes into cleaning mode by itself (Oven Repair (including Ranges and Cooktops))
by CyberDad 12/15/2009 10:18:28 AM(UTC)
by laarman 10/8/2009 9:53:48 AM(UTC)
Oven won't shut off (Oven Repair (including Ranges and Cooktops))
by blackcote 5/29/2009 10:43:37 AM(UTC)
by charlie3198 5/27/2009 12:31:56 PM(UTC)
Amana electric oven won't shut off (Oven Repair (including Ranges and Cooktops))
by Kirkfarley 4/25/2009 6:34:23 AM(UTC)
by boater08 11/22/2008 9:22:02 AM(UTC)
by RickG 1/21/2008 8:15:58 AM(UTC)
