2 Pages12>
KRCASON
#1 Posted : 16 years ago
KRCASON
Fridge quit cooling, but freezer is fine. Local repair shop through Samsung has made 3 attempts to repair, but no luck. Out of warranty. I studied the Samsung manual and disassembled panel inside fridge compartment and found evap assy completely frozen up with ice in ducts of panel. Manually defrosted, reassembled, but refroze in 5 days. Checked codes on computer panel on fridge and it has a "ref def heater error". Checked continuity on heater element and there was no continuity. Can defrost element be replaced or do I need the whole evap assy? How difficult to replace? Appears to be one unit (defroster and evap) Works great as long as I remove panel and manually defrost with "hair dryer".
crika
#2 Posted : 16 years ago
crika
Where can I find the diagnostic codes for this refrigerator?I pressed the power freeze and power cool buttons simultaneously to test.You have two digits indicating the freezer temperature.On the second digit there is a single dash lit up on the bottom of the number.Any help finding codes would be greatly appreciated.
#3 Posted : 16 years ago
crika
#4 Posted : 16 years ago
crika
Thanks for the wealth of info! YOU ARE DE (N) MAN!
crika
#5 Posted : 16 years ago
crika
thanks........
texascats
#6 Posted : 15 years ago
texascats
Had the same issue and after replacing the board, a fan, and a thermocouple, they finally had to take the fridge into the shop to remove the freon and cut through the copper by the evap assy to replace a probe inside. Service and parts were covered under 5 year warranty. Just got fridge back today.:)
wilsonb
#7 Posted : 14 years ago
wilsonb
Ive got the same problem. Defrosted with blow dreyer and it refroze 5 days later.
Any solution to this? I don't know if the defroster inside is out or the computer is not telling it to defrost. Im almost tempted to wire in a manual swith .
Any info will help on this common problem
texascats
#8 Posted : 14 years ago
texascats
Had the same issue, the problem is with the evaporative assembly, the service guy finally took the fridge into the shop to remove the freon and cut through the copper by the evap assy to replace a probe inside. Service and parts were covered under 5 year warranty. Have not had any other issues.
Read more: http://forum.appliancepartspros...post270074#ixzz0yryL4luf
http://forum.appliancepartspros.com
wilsonb
#9 Posted : 14 years ago
wilsonb
Could you take a photo of where it is located? I have the service manual, but when you talk about them having to cut copper and remove freeon to get to it, makes me worried..
Is there more info on how to "Do it yourself"
texascats
#10 Posted : 14 years ago
texascats
Sorry I don't have pictures, but after you have removed everything and just have the coils showing, on the upper left of the coils there is the part that I believe goes into the back of the refridgerator, anyway there is a probe encased in that part and the only way to get to it is to cut through to it to change it out, solder it back and replace the freon. The service that worked on my fridge, which is a RS267LASH, is Concho Valley Appliance Service in San Angelo, TX, phone 325-949-6809, and ask for Homer, he is the technician that worked on it. I am sure he will remember and can give you more specifics of what needs to be done. The part is covered under a 5 year warranty.
2 Pages12>
