Our Fridge is having the same trouble. I noticed it wasn't as cold and stuck my thermometer and realized the one on the front was wrong. It was saying on the front it was 34 but my manual temp. was saying 50. Called the repair man 2 days before warranty was running out. They came out, temp. fixed it and ordered replacement coils. Came back in 4 days and replaced coils and said thermostat was good and heater was good. It's been a week or so and it's not cooling again. 50 again. So I'm guessing it's the same thing, sounds the same. What is the turn around time on repairs. We can't go too long with out a fridge. thanks
sorry know this is a long time ago but did you solve your defrosting problem on samsung fridge? my evap fan in the arctic select drawer is completely frozen and after manual defrost its doing it again 12 hours later. Error codes give defrost sensor for cf compartment and fan motor abnormality in cf compartment so know I am in the right area.
any fresh link, may tag does.t open...!!!
THIS FORUM IS DEAD!!!!!!! |
hi, sorry, nothing about our model (labeled Samsung,, but probably whirlpool or any other brand sold under such samsun g name,,,) the model is a two doors, no water or ice dispense er, eerie RS20 (like Whirlpool brand) but following letters are rs20 -CRSB...
any option to a CD or DVD repair manual send by Fedex ?
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hola. Mi refri tiene fuga de agua por la manguera blanca y provoca hielo, luego se traba el ventilador y después ya no enfría. Cómo puedo eliminar el agua acumulada. No uso el filtro ni los cubitos. Pero dejo agua acumulada. Puedo cortar la manguera blanca de extremo a extremo para poder sacar toda el agua?. Respuesta por favor. Gracias
