Doug II
#1 Posted : Saturday, November 3, 2007 5:41:34 PM(UTC)
Doug II
Dryer stopped heating.
We have good power to the unit. The gas line is delivering gas.
The igniter doesn't ignite. Everything is clean and looks in good shape.
#2 Posted : Sunday, November 4, 2007 1:36:57 AM(UTC)
Post back when you get a meter.
Doug II
#3 Posted : Sunday, November 4, 2007 7:35:47 AM(UTC)
Doug II
I've got a meter and the diagram of the burner assembly.
What do I do now?
#4 Posted : Sunday, November 4, 2007 6:02:18 PM(UTC)
First I would check the igniter for continuity, if none, just replace it.
If ok check the main connector for the gas valve assembly. Should have 115 volts. If not trace back to the timer for missing voltage and post results.
jayboy
#5 Posted : Monday, November 5, 2007 8:36:14 PM(UTC)
jayboy
I just spent the entire day fixing my gas dryer. If the igniter never glows, then check the continuity of the thermal fuse. Just remove the back panel, and you will find the thermal fuse near the bottom center of the back of the dryer. It is located on the blower housing and attached with one machine screw. On my dryer there is a red and blue wire connected to the terminals of the fuse. A real easy fix if that is the problem.
Doug II
#6 Posted : Tuesday, November 6, 2007 7:48:44 AM(UTC)
Doug II
It's the thermal fuse.....thanks a million
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
