lakedout
#1 Posted : Monday, October 29, 2007 7:50:01 AM(UTC)
lakedout
Water dispenser does not turn off when glass is removed. What part needs to be replaced?
#2 Posted : Monday, October 29, 2007 11:46:08 AM(UTC)
Hi lakedout
To find out exactly which part is bad - the water valve coil or the switch in the water dispenser you should run a pretty simple test.
You'll need a second person to help you.
Locate the water inlet valve on the back of the fridge and the coil for the water dispenser. (The water line for the water dispenser should be 5/16").
Depress and release the water dispenser lever and remove the electrical plug from the coil.
If water stopped right after you removed the plug then the water inlet valve has to be replaced. If not then the problem is a bad switch in the water dispenser.
- The part number for the water inlet valve AP3160649
- The part number for the switch AP3131893
- Here are the break down diagrams for the Kitchen Aid refrigerator Model KSRS25IHWH02
Good luck.
Admin / APP Team
#3 Posted : Tuesday, October 30, 2007 10:18:20 AM(UTC)
Admin / APP Team
Rank: Administration
From lakedout's email:
"Hi Gene:
Many thanks. I believe it is the switch since the icemaker continues to function OK."
lakedout
#4 Posted : Saturday, November 3, 2007 6:33:04 AM(UTC)
lakedout
Gene FYI:
Problem was not the switch nor the valve - it was air in the plastic loop storage (behind the refrigerator bottom meat drawer). After I eliminated the air pockets, the dispenser works fine.
supra24valve
#5 Posted : Sunday, November 18, 2007 4:04:47 PM(UTC)
supra24valve
How did you get the air out?
lakedout
#6 Posted : Monday, November 19, 2007 7:28:33 AM(UTC)
lakedout
Just bleed the water line - be sure to use a large container, as it may take a while!
Ice and water dispenser beeps only (Refrigerator & Freezer Repair)
by Guest 5/31/2024 7:53:16 AM(UTC)
Frigidaire Gallery dripping through water dispenser (Refrigerator & Freezer Repair)
by cascodo 5/6/2024 9:26:01 PM(UTC)
water dispenser sporadically dispenses water (Refrigerator & Freezer Repair)
by ddxxoo 3/20/2024 2:55:42 PM(UTC)
Water dispenser not working GE Profile PSHs6TGXBDS (Refrigerator & Freezer Repair)
by klkaylor78 2/3/2024 11:07:08 AM(UTC)
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest 1/11/2024 5:03:35 AM(UTC)
water dispenser stopped working. No light no pwer (Refrigerator & Freezer Repair)
by waterdispprob 11/19/2023 10:08:39 AM(UTC)
Frigidaire Gallery ice maker sending water to water dispenser?? (Refrigerator & Freezer Repair)
by jonny comfort 6/11/2023 7:49:11 PM(UTC)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Kenmore Coldspot model 106.9555611 Water Dispenser (Refrigerator & Freezer Repair)
by reynolpe 2/14/2023 1:40:10 PM(UTC)
LG Fridge - Water Dispenser barely flowing (Refrigerator & Freezer Repair)
by AZ_Desert 1/28/2023 7:03:14 AM(UTC)
Ice Maker not filling with water. Water dispenser works. Kenmore Elite (Refrigerator & Freezer Repair)
by jeffrich12 1/21/2023 9:13:34 AM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Whirlpool Refrigerator inside lights, ice and water dispenser doesn't work (Refrigerator & Freezer Repair)
by Guest 1/6/2023 5:15:20 PM(UTC)
electrolux fridge Water dispenser doesn’t work (Refrigerator & Freezer Repair)
by max57 10/28/2022 2:33:45 PM(UTC)
Electrolux Refrigerator Water Dispenser Sticks Open (Refrigerator & Freezer Repair)
by Thom64 7/30/2022 8:42:45 AM(UTC)
