choldca
#1 Posted : 17 years ago
choldca
I recently used the self-clean option on my top oven and after the cycle was complete, I no longer got any heat from either element. You wouldn't know it since the controls and fans seem to operate, it's just that the oven doesn't get hot. The bottom oven, which i didn't self-clean, is working fine. I see others have a similiar problem after using the self-clean option. Does this make sense? Are there 2 thermal fuses per oven?
Any help would be appreciated! I don't think this is something I may be able to fix myself.
Thanks!
Cindy
#2 Posted : 17 years ago
Hi Cindy
Most likely the problem with your oven is a blown thermal cut off due to very high temperature during the self clean. In order to replace the part, the oven has to be removed from the cabinet.
If you are ready to do it yourself, I need you to post the complete model number of the oven. You can find it on the right side of the upper oven door frame.
choldca
#3 Posted : 17 years ago
choldca
Thanks Gene for the prompt response! I have seen a few problems with this oven following self clean. I am not going to fix it myself, unfortunately will have to call someone in to do it. Glad to understand the problem however was not by me touching something.
talleyklotz
#4 Posted : 16 years ago
talleyklotz
Hi Gene,
I'm looking for directions how to replace the thermal fix on my Whirlpool double wall oven model #RBD306PDQ10.
The bottom oven has stopped heating following a self clean cycle. The fan and the control panel are still working.
I purchased a Thermal Fix part number: 1061375
Part 1061375 from RepairClinic.com
Thinking I was purchasing from your site, but apparently I was not. Can you tell me if I purchased the right part or do I need a Thermal Fuse (part#: AP3110028)?
Also, I need directions on how to replace.
Thanks so much!
Amy
talleyklotz at hotmail dot com
#5 Posted : 16 years ago
Originally Posted by: talleyklotz Go to Quoted Post
...I purchased a Thermal Fix part number: 1061375...Can you tell me if I purchased the right part or do I need a Thermal Fuse (part#: AP3110028)?...
...Also, I need directions on how to replace...
You purchased the correct part but looks like you overpaid a lot. Appliance Parts Pros part number for this thermal cut-off is AP3030381 and you could buy it for just $31.65
You have to remove the oven from the cabinet and remove the rear cover to access this part.
Here are the break down diagrams and Replacement parts for WHIRLPOOL RBD306PDQ10 | AppliancePartsPros.com
talleyklotz
#6 Posted : 16 years ago
talleyklotz
Thanks Man! Oh yes and thanks for pointing out the extra 15 bucks I shelled out ;-)
Ok, so I was on the right track. Thanks for the diagram.
You guys rock btw and I was surprised that I hadn't ordered it from you... I must have gotten interrupted by a screaming kid or something and came back to the wrong page. My bad.
talleyklotz
#7 Posted : 15 years ago
talleyklotz
I just wanted to say that this is a correct and easy fix. Don't be afraid to do it yourself. It took me 10 mins and the help of my husband's muscles to fix and now I've done it for 2 of my neighbors.
This forum is awesome!
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 3 years ago
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 7 years ago
Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by PotRoastMan 10 years ago
by dragonflies64 10 years ago
Whirlpool double wall oven (electric) upper oven not working (Oven Repair (including Ranges and Cooktops))
by JayTeeC 11 years ago
Whirlpool Double Wall Oven (Oven Repair (including Ranges and Cooktops))
by abinosa 12 years ago
Whirlpool Double Wall Oven Fan (Oven Repair (including Ranges and Cooktops))
by bernardv 13 years ago
by myoven 13 years ago
Removing trim and control panel from Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by Lifterfe 14 years ago
Whirlpool double wall oven E6 F2 code, then blank display (Oven Repair (including Ranges and Cooktops))
by jvr888 14 years ago
Whirlpool Double Wall Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by DaveinMD 15 years ago
by jledereich 15 years ago
Whirlpool Double Wall Oven D.O.A (Oven Repair (including Ranges and Cooktops))
by JaredB 16 years ago
Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd (Oven Repair (including Ranges and Cooktops))
by sillyshopper 17 years ago
