jeromeagrant
#1 Posted : Sunday, December 21, 2008 1:28:42 PM(UTC)
jeromeagrant
my dryer runs and heats up,but the timer doesnt move,i have to push the start button and it will run forever.It will dry the clothes but I have to check on it or it will really get them hot.Is this a problem with timer or other things.
#2 Posted : Sunday, December 21, 2008 5:00:46 PM(UTC)
Cannot find any info on the given Model Number.
There is data on REX5634KQ1, is this the correct number?
jeromeagrant
#3 Posted : Monday, December 22, 2008 4:13:18 AM(UTC)
jeromeagrant
yes , that is the correct model number.
kayakcrzy
#4 Posted : Monday, December 22, 2008 4:45:36 AM(UTC)
kayakcrzy
I would replace the timer. Part # is 8299781.
#5 Posted : Monday, December 22, 2008 5:41:31 AM(UTC)
Here is your parts
Model REX5634KQ1
Here is a tech sheet
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
Try timed dry. Now does the timer advance?
If it does the the following may apply.
Take a look at the timing chart, you will see that timed and auto use different timer contacts re: TM-OR or TM-WB.
In timed dry the timer motor gets power direct from 120 volts (Neutral to L1)
In auto timer motor only gets power when the heating elements shuts off. This puts L2 voltage on the left side of the element, the Resistor drops the 240 down so it does not blow the timer motor. If the element never shuts off then the timer will not advance.
Most probable cause is a grounded element.
Unplug the unit.
Remove wires from the element.
Check resistance between element connectors, should be approx 10 ohms.
Check each connector to ground should be open (infinite resistance).
If you do not have a meter, inspect the element visually. You may be able to see where it is touching the case or a scorch mark where it has touched the case.
Another possibility would be the inline timer resistor or the operating thermostat.
Timer doesn't move from rinse to dry. (Dishwasher Repair)
by rmwalt 4/17/2012 11:05:42 AM(UTC)
Sears Galaxy Electric dryer no heat,timer doesn't move (Dryer Repair)
by melindascrochet 5/2/2011 7:38:20 AM(UTC)
Dryer Heats Timer Doesn't Move (Dryer Repair)
by johnf0246 2/16/2010 10:45:51 PM(UTC)
Timer doesn't move no heat (Dryer Repair)
by Miknur 12/18/2009 8:33:02 AM(UTC)
No heat and timer doesn't move (Dryer Repair)
by omahagirl76 1/26/2009 6:29:22 PM(UTC)
no heat-timer doesn't move on PP setting (Dryer Repair)
by llyod 12/22/2008 5:16:39 PM(UTC)
Timer doesn't move (Dryer Repair)
by smcgilbray 11/14/2008 8:35:07 AM(UTC)
