oleblueyes
#1 Posted : Saturday, August 13, 2011 5:05:33 AM(UTC)
oleblueyes
I need to removal the ice maker to replace the a broken bolt that holds the mechcanism that drives the auger. How do I release the ice maker so that it will slide forward?
Jeff / APP Team
#2 Posted : Saturday, August 13, 2011 5:18:23 AM(UTC)
Jeff / APP Team
Hello oleblueyes.
Remove the Ice bucket.
Remove the Phillips-head screw that attaches
the front of the wire harness cover.
Using a small flatblade screwdriver, pry the
front of the cover out, then pull the cover
towards the front of the refrigerator.
Note the routing of the icemaker wire harness,
then disconnect the harness.
Push in the release tab on the front of the
icemaker, then pull the icemaker out of the ice
room. When installing icemaker, engage key slots in
key tabs before pushing icemaker in place.
Hope this helps.
oleblueyes
#3 Posted : Saturday, August 13, 2011 4:21:35 PM(UTC)
oleblueyes
thanks Jeff,
I have removed the wire harness cover and disconnected the wiring harness. However, I am not locating the release tab. Is there a picture I can access to help me locate this?
Jeff / APP Team
#4 Posted : Monday, August 15, 2011 4:04:31 AM(UTC)
Jeff / APP Team
I dont have a picture of it to upload, but according to the manufacture, it should be located in the left side wall of the ice box. Hope this helps.
Ice maker removal, side by side Whirlpool (Refrigerator & Freezer Repair)
by tizzmo 5/24/2021 12:58:40 PM(UTC)
Ice Maker Removal - LG freezer (Refrigerator & Freezer Repair)
by jameshere 3/22/2012 2:40:23 PM(UTC)
Ice maker removal (Refrigerator & Freezer Repair)
by Gail Marie 11/12/2011 8:50:19 AM(UTC)
Ice maker removal procedure (Refrigerator & Freezer Repair)
by fishnjim 6/6/2011 9:32:52 AM(UTC)
Ice Maker Removal (Refrigerator & Freezer Repair)
by Gyro-Gearloose 11/22/2010 3:58:08 AM(UTC)
Maytag MFI2269VEM Ice Maker Removal (Refrigerator & Freezer Repair)
by Aquitard 11/10/2010 8:49:56 AM(UTC)
by cfuller201 6/11/2010 12:12:21 PM(UTC)
by delbertbstapp 1/31/2008 11:05:20 AM(UTC)
