deekay
#1 Posted : 16 years ago
deekay
My oven door handle is loose. How do I fix it?
#2 Posted : 16 years ago
Remove the door from the oven as described in the Owner manual(page 25). Put the door on a flat surface with the door handle down. Remove the screws holding the door liner. Remove the door liner to access the door handle screws.
Here are the break down diagrams for the Whirlpool range Model RF315PXDN0
deekay
#3 Posted : 16 years ago
deekay
Thanks for the advice . The handle was a breeze to fix.:) :) :) :)
#4 Posted : 16 years ago
I'm glad you were able to fix it.
jimgo
#5 Posted : 16 years ago
jimgo
Hi I also have a Whirlpool. ModelWEP84800, type 30P, bought it in 1998 and its an accubake model.
I read the above, and our door will pull off the same way - but all the screws to the handle are recessed - what are the steps we would take, once the door is off? to get to that handle?
#6 Posted : 16 years ago
jimgo,
The model number you posted does not come up. Verify and repost it.
jimgo
#7 Posted : 16 years ago
jimgo
I rechecked it, and thats the model number. Tried to snap a picture of it, but the sucker is hard to focus on. Could the problem be its a canadian model?
jimgo
#8 Posted : 16 years ago
jimgo
not the best model number, in fact quite unreadable, as it was a cellphone camera, but to the best of my ability its wep84800
jimgo attached the following image(s):
#9 Posted : 16 years ago
Yes, Canadian models are not listed on American sites. I found the break down diagram for your door: Whirlpool Parts Model Display and hope it will help you.
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 3 years ago
How to replace oven door handle on my Kenmore Range (Oven Repair (including Ranges and Cooktops))
by PaullyK 11 years ago
Oven Door handle (Oven Repair (including Ranges and Cooktops))
by Menterj 12 years ago
Oven Door Handle Replacment (Oven Repair (including Ranges and Cooktops))
by crnlmgt 12 years ago
Oven Door Handle Repair (Dryer Repair)
by CannonballJack 12 years ago
Oven Door Handle (Oven Repair (including Ranges and Cooktops))
by Ben2 13 years ago
oven door handle coming off (Oven Repair (including Ranges and Cooktops))
by dyanne rooney 13 years ago
Maytag Oven Door Handle Replacement (Oven Repair (including Ranges and Cooktops))
by lucaswoman 14 years ago
Install Oven Door Handle (Oven Repair (including Ranges and Cooktops))
by RU10962 14 years ago
Oven door handle is loose (Oven Repair (including Ranges and Cooktops))
by mflips 14 years ago
Need help assembling Whirlpool oven door handle (Oven Repair (including Ranges and Cooktops))
by SauravSengupta 14 years ago
Kitchen Aid oven door handle loose (Oven Repair (including Ranges and Cooktops))
by macor1 14 years ago
Kit Aid Oven Door Handle Loose/Window Dirty (Oven Repair (including Ranges and Cooktops))
by JMBonn 15 years ago
Jenn Air Oven Door Handle has come off (Oven Repair (including Ranges and Cooktops))
by Louise Galvin 15 years ago
