Louise Galvin
#1 Posted : Monday, March 15, 2010 9:50:23 AM(UTC)
Louise Galvin
My Jenn Air range is Model JER8850AAB and the oven door handle had loosened up. When I removed the top screws from the door trim to try to gain access to the screws in order to tighten the handle, the handle actually came off the door. The top of the door trim is tight and won't budge. How do I remove the trim? Can I apply pressure in a particular area, do I use a screwdriver to try to pry it, etc? I really would appreciate your help in either sending me a diagram or explaining to me how I can properly and securely replace the handle. Thank you very much.
Guest
#2 Posted : Wednesday, December 8, 2021 8:05:53 AM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
How do I remove the door on our model svd48600p downdraft Gastop elect. Oven
