The door handle on my whirlpool GBS307PRB01 has broken, I found the parts required, how do you install the new handle, looks like the interior assembly needs to come off to get at the screws that secure the handle to the exterior frame? Thanks for you help
Groups: APP Team
Hi.
You are right the front glass has to come off in order to replace the door handle. There should be two brackets at the bottom of the door, remove them and you should be able to take the front off.
Simon.
