mfd
#1 Posted : Monday, October 29, 2007 9:47:56 AM(UTC)
mfd
I have a bottom freezer refrigerator. I have the fridge set at the coldest setting, but it does not get colder than 40 degrees and most of the time is higher than that. It doesn't seem to run enough, it shuts off before it gets cold. The freezer runs fine.
#2 Posted : Monday, October 29, 2007 9:53:17 AM(UTC)
Hi mfd
In order to provide the most accurate advise I need the complete model number of your fridge.
mfd
#3 Posted : Monday, October 29, 2007 10:03:07 AM(UTC)
mfd
The model number is 596.68142791.
#4 Posted : Monday, October 29, 2007 10:21:46 AM(UTC)
The first thing I would do is check the back panel inside the freezer. If it's covered with a snow then there is a problem with the defrost system. Also check if the evaporator fan is working properly. The fan is located behind the back cover in the freezer and should run when the compressor is running.
Let me know what you found.
mfd
#5 Posted : Monday, October 29, 2007 11:03:31 AM(UTC)
mfd
I checked the back panel in the freezer, there is no frost. Also, the fan seems to be running fine, there is lots of air coming out the back of the freezer and I can hear it running.
#6 Posted : Monday, October 29, 2007 11:19:47 AM(UTC)
Check the damper control in the fresh food compartment now. The gate should be open if the temperature is too warm. If the gate is closed replace the dumper control. Also check for any blockage in the air exchange window.
- The part number for the damper control AP100860
The damper control
UserPostedImage
Good luck.
#7 Posted : Monday, October 29, 2007 12:33:48 PM(UTC)
Seems like an overheating compressor, pull back panel and check condensing fan and see if the compressor is running really hot.
mfd
#8 Posted : Wednesday, November 28, 2007 8:27:09 AM(UTC)
mfd
My refrigerator has been closed all night, I just checked the temperature in the fridge, it is 42 degrees. I have the dial turned to as cold as possible, and the fridge is not running right now. It dosen't seem to run enough.
abbie
#9 Posted : Wednesday, November 28, 2007 10:41:44 AM(UTC)
abbie
if the the thermostat is not solid state ,an is the old style thermostat with a sensing bulb ,it can be adjusted to be colder,looking at the thermostat close up, there a small screw which when turned counter clockwise will make the unit [fridge] colder. Only turn this screw no more then 1/8 to 1/4 of a turn. Also check to see if the light is not staying on when door is closed.lol.
Whirlpool Refrigerator not cold enough (Refrigerator & Freezer Repair)
by bsmcc 3/22/2016 6:52:44 AM(UTC)
Frigidaire Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by wing471 9/7/2015 5:42:56 AM(UTC)
Freezer cold but not freezing, refrigerator not cold enough (Refrigerator & Freezer Repair)
by tyltea1st@charter.net 6/5/2014 6:06:36 AM(UTC)
by mansoura 11/26/2013 5:28:11 AM(UTC)
Freezer & Refrigerator not cold enough (Refrigerator & Freezer Repair)
by HFrank 5/30/2013 10:53:56 AM(UTC)
Freezer and Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by mahplane 8/29/2012 9:11:03 PM(UTC)
by tonlam 11/30/2011 7:02:14 AM(UTC)
Magic Chef Refrigerator Freezer work Refrigerator not cold enough (Refrigerator & Freezer Repair)
by tg06222 9/3/2011 3:28:36 PM(UTC)
GE Profile Arctica Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by Snap50 7/25/2011 6:11:51 PM(UTC)
Kenmore refrigerator not cold enough (Refrigerator & Freezer Repair)
by Malinda 5/14/2011 7:00:23 AM(UTC)
by teresa in mo 4/25/2011 5:33:30 AM(UTC)
by davidwaynesmith 4/8/2011 5:16:07 AM(UTC)
Freezer and Refrigerator not cold enough (Refrigerator & Freezer Repair)
by fionmay 1/22/2011 10:57:42 AM(UTC)
Side by side refrigerator not cold enough (Refrigerator & Freezer Repair)
by Bhedman 1/8/2011 7:32:16 AM(UTC)
Frigidaire side by side refrigerator freezer working refrigerator not cold enough (Refrigerator & Freezer Repair)
by SSOWDERS 9/15/2009 6:15:20 PM(UTC)
