Ngs
NGS
#1 Posted : Wednesday, December 10, 2008 2:32:54 PM(UTC)
NGS
Oven stoped working. First, elements were a bit worm but now they dont heat at all. Range is working, clock shows temp and fan is running when preheating.:confused:
What could go wrong?
Gord
libertyappl
#2 Posted : Wednesday, December 10, 2008 2:50:14 PM(UTC)
libertyappl
Not sure if this is your exact model, Model PGLEF385CS4
The temp sensor (#37) on page 2 or possible a loose or broken wire on the back of the unit.
Nat
NGS
#3 Posted : Wednesday, December 10, 2008 3:04:49 PM(UTC)
NGS
Thanks Nat, quick response is well appreciated.
Model # is correct.
How can I check if it's the sensor?
Gord
libertyappl
#4 Posted : Wednesday, December 10, 2008 3:06:37 PM(UTC)
libertyappl
You will need to open the unit up and use an ohm meter to see if it has continuity thru it.
FYI, if it's not the sensor or a loose wire, the control board has been discontinued, so we'll pray for an easy repair!!
nat
NGS
#5 Posted : Wednesday, December 10, 2008 3:38:13 PM(UTC)
NGS
Thank you Nat,
I hope it will be the quick fix and pray it's not the EOC.
One more question,... could the faulty termostat be the posible cause?
Gord
libertyappl
#6 Posted : Wednesday, December 10, 2008 4:24:30 PM(UTC)
libertyappl
Your unit doesn't have a traditional thermostat.
Nat
Guest (4)
Savings through Textbook Rentals (General Talk)
by Guest 6/25/2024 4:12:42 AM(UTC)
Maximizing Savings through Textbook Rentals (General Talk)
by Guest 6/9/2024 10:31:43 PM(UTC)
Thermal fuse ratings and interchangeability on dryers (Dryer Repair)
by Guest 12/17/2023 10:57:55 AM(UTC)
Maytag MVWC565fw1 bangs around (Washer Repair)
by polku3 8/24/2023 12:40:09 PM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
Kenmore 592-89032 Dryer POWERS OFF mid-cycle on both timer and moisture settings (Dryer Repair)
by Guest 7/15/2023 6:11:04 AM(UTC)
Whirlpool WTW5800BW0 drum bearings? (Washer Repair)
by edw00app 5/23/2023 2:02:04 PM(UTC)
Windings Test (Refrigerator & Freezer Repair)
by Guest 2/10/2023 4:31:21 AM(UTC)
Kitchen Aid Combo Microwave Door Flops Open Even After Springs (Oven Repair (including Ranges and Cooktops))
by chrison600 11/19/2022 11:33:49 AM(UTC)
Basic things need on Cricket (Trash Compactor Repair)
by Johnalex 7/6/2022 11:07:18 PM(UTC)
Compressor readings (Refrigerator & Freezer Repair)
by dbdata 9/8/2021 9:08:19 AM(UTC)
HBL5650UC/06 Bosch Double Wall Oven Settings Dial Going Crazy (Oven Repair (including Ranges and Cooktops))
by DB44 2/1/2021 5:49:38 PM(UTC)
KEMC308kss03 - replaced the torsion springs and the door still has no tension (Microwave Repair)
by mplsavant 1/4/2021 6:30:41 AM(UTC)
Kithenaid fridge bangings twice a day loudly at 3:30 am and 8:30 pm (Refrigerator & Freezer Repair)
by cjunk 6/28/2020 8:39:08 AM(UTC)
Whirlpool Quiet Partner IV hangs at 97 or 44 min (Dishwasher Repair)
by CasaCasa 4/1/2020 8:32:35 AM(UTC)
