2 Pages12>
twodesk
#1 Posted : Tuesday, December 9, 2008 6:04:18 PM(UTC)
twodesk
refrig making whooling sound i change the circuit board the sound went a way now the freezer seems to be working but not cold enough also the fresh food compartment is at 50 degrees also a little frost build up on the wall of the freezer compartment
abadfish66
#2 Posted : Wednesday, December 10, 2008 9:39:06 AM(UTC)
abadfish66
Is the freezer fan running?
twodesk
#3 Posted : Wednesday, December 10, 2008 11:41:35 AM(UTC)
twodesk
yes the freezer is running at least i here the motor running
abadfish66
#4 Posted : Wednesday, December 10, 2008 12:08:28 PM(UTC)
abadfish66
Did you follow the directions on the replacement board reguarding cutting a jumper wire if the jumper was present?
twodesk
#5 Posted : Wednesday, December 10, 2008 12:15:26 PM(UTC)
twodesk
the instruction says to cut ONLY on bottom freezer so i did not cut
abadfish66
#6 Posted : Wednesday, December 10, 2008 12:54:44 PM(UTC)
abadfish66
Wrong, on the bottom freezers it shows you to cut the white wire in pin2, on the SxS refers there is a blue jumper wire between pins 8 and 9 if that is there, it needs to be cut... The instructions say "All bottom Freezer models", but below that it says "Encoder models with the following serial number" and gives you the serial #'s of the ones that may need to be cut, this is for the SxS refers
twodesk
#7 Posted : Wednesday, December 10, 2008 1:13:27 PM(UTC)
twodesk
I have blue jumper wire pin 6 & 8 and a blue jumper wire in 5 & 6 pin #9 is empty also decorder on the bottom of instrution does not list gsh models
thanks I apprieate the help
abadfish66
#8 Posted : Wednesday, December 10, 2008 1:33:09 PM(UTC)
abadfish66
I meant a jumper in pins 1 and 2, sorry. Also the instructions don't list model#'s, just a list of the first 3 parts of the serial#. So if the jumper is not there we'll move on... Open the fresh food door, and with one hand push the light switch closed, and with the other feel if you have any air coming in through the damper door. "the box on the left top wall of the freshfood section" Keep feeling for about 30 seconds
twodesk
#9 Posted : Wednesday, December 10, 2008 1:41:52 PM(UTC)
twodesk
Air Is Very Very Slight
abadfish66
#10 Posted : Wednesday, December 10, 2008 1:47:26 PM(UTC)
abadfish66
You will need to remove the rear panel of the freezer, and see if the evaperator is full of compacted frost, or a light fluffy coat of frost, or hardly any frost at all.
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 1/23/2022 3:19:31 AM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 5/30/2021 2:59:27 PM(UTC)
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 1/21/2021 11:39:19 AM(UTC)
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 12/19/2020 6:58:00 AM(UTC)
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 11/5/2020 4:08:04 AM(UTC)
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5/16/2020 10:05:38 AM(UTC)
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 9/12/2019 5:32:28 AM(UTC)
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 2/28/2019 2:46:16 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 11/25/2018 12:13:04 PM(UTC)
2 Pages12>
