refrig making whooling sound i change the circuit board the sound went a way now the freezer seems to be working but not cold enough also the fresh food compartment is at 50 degrees also a little frost build up on the wall of the freezer compartment
Is the freezer fan running?
yes the freezer is running at least i here the motor running
Did you follow the directions on the replacement board reguarding cutting a jumper wire if the jumper was present?
the instruction says to cut ONLY on bottom freezer so i did not cut
Wrong, on the bottom freezers it shows you to cut the white wire in pin2, on the SxS refers there is a blue jumper wire between pins 8 and 9 if that is there, it needs to be cut... The instructions say "All bottom Freezer models", but below that it says "Encoder models with the following serial number" and gives you the serial #'s of the ones that may need to be cut, this is for the SxS refers
I have blue jumper wire pin 6 & 8 and a blue jumper wire in 5 & 6 pin #9 is empty also decorder on the bottom of instrution does not list gsh models thanks I apprieate the help
I meant a jumper in pins 1 and 2, sorry. Also the instructions don't list model#'s, just a list of the first 3 parts of the serial#. So if the jumper is not there we'll move on... Open the fresh food door, and with one hand push the light switch closed, and with the other feel if you have any air coming in through the damper door. "the box on the left top wall of the freshfood section" Keep feeling for about 30 seconds
You will need to remove the rear panel of the freezer, and see if the evaperator is full of compacted frost, or a light fluffy coat of frost, or hardly any frost at all.
