Russ T
#1 Posted : Tuesday, December 9, 2008 12:12:35 PM(UTC)
Russ T
When the washer reaches Rinse on the timer, the machine will not advance any further in the cycle. What part needs to be replaced?
Drags1998
#2 Posted : Tuesday, December 9, 2008 1:34:58 PM(UTC)
Drags1998
Does the washer DRAIN? If not, check the LID-Switch, If it does drain, check to see if you get cold water coming into the washer!!!!
Russ T
#3 Posted : Tuesday, December 9, 2008 1:38:27 PM(UTC)
Russ T
Yes, the washer will drain if I manually move the dial past the "rinse" mark. The washer will complete its cycle. It seems to get hung up when it hits rinse.
Drags1998
#4 Posted : Tuesday, December 9, 2008 1:52:13 PM(UTC)
Drags1998
It sounds like the TIMER has a dead spot in it. The only thing to do is replace the Timer!!! Before you run out and buy a timer, Try 1 of the other cycles, MY guess is that it will go thru the other cycles OK. If it does, REPLACE the TIMER!!!:)
Russ T
#5 Posted : Tuesday, December 9, 2008 1:53:35 PM(UTC)
Russ T
I will try that. Thank you!
Guest (6)
kitchenaid washer kaws800gq1 (Washer Repair)
by maagk 7/10/2020 5:47:30 AM(UTC)
Kitchenaid washer does everything but spin (Washer Repair)
by donohu40 10/27/2016 7:34:05 AM(UTC)
KitchenAid washer stopped spinning (Washer Repair)
by Punisher Bass 7/10/2015 4:30:16 PM(UTC)
need helpplease with trouble shooting kitchenaid washer (Washer Repair)
by lmormsby 5/14/2014 2:55:31 PM(UTC)
Older kitchenaid washer that worked fine and then? (Washer Repair)
by yepyepdude 1/29/2014 7:30:32 AM(UTC)
Kitchenaid washer pulling my hair out! (Washer Repair)
by DANShandy 7/29/2013 4:28:39 AM(UTC)
KitchenAid Washer Weird Issue -Electrical? (Washer Repair)
by zee652 4/2/2013 8:17:05 AM(UTC)
KitchenAid Washer won't drain or spin (Washer Repair)
by MSUMOM 3/14/2013 7:25:53 PM(UTC)
KitchenAid Washer (Washer Repair)
by ellmer 9/25/2012 1:25:15 PM(UTC)
kitchenaid washer won't spin (Washer Repair)
by rdtjr1968 9/23/2012 2:54:36 PM(UTC)
a Kitchenaid washer (Washer Repair)
by wapanstore 2/20/2012 8:15:00 PM(UTC)
kitchenaid washer throwing fault codes (Washer Repair)
by buldog9 1/18/2012 11:45:18 AM(UTC)
by carrisal 10/13/2011 3:22:01 PM(UTC)
by carrisal 9/30/2011 2:45:01 PM(UTC)
by murielh 5/22/2011 9:25:08 AM(UTC)
