25 Pages«<45678>»
mechanicallydmb
#51 Posted : 14 years ago
mechanicallydmb
Hi Gene, thank you. Should I purchase an entire unit for the small difference? I would think so...thanks again.
jdhahn79
#52 Posted : 14 years ago
jdhahn79
Gene,
I have been reading these boards looking for advice. You seem extremely knowledgable with regards to ice makers. I was hoping you might have some advice for my situation. I posted a thread about it but have not received any replies. Thanks in advance.
http://forum.appliancepartspros...2-samsung-ice-maker.html
#53 Posted : 14 years ago
You may want to replace the optic boards first. It is possible there is nothing wrong with the ice maker yet.
mechanicallydmb
#54 Posted : 14 years ago
mechanicallydmb
Hi Gene, I replaced the optic boards as you told me and I am getting ice but the red let is blinking twice and it stays red when I hold the flap on the left down. Could the red light be there because I need to replace the filter or for some other reason? thanks for all your help!
#55 Posted : 14 years ago
The LED is blinking when the optical beam is blocked. If it happens while the emitter door is open then it's normal.
mechanicallydmb
#56 Posted : 14 years ago
mechanicallydmb
Hi Gene, my question was as to the color. Why is it red? I remember that it used to be green when it worked properly in the past. Thank you again.
#57 Posted : 14 years ago
Actually it's more orange than red. I don't remember this light to be green.
The water filter status light is located at the top of the refrigerator compartment.
tstewart
#58 Posted : 14 years ago
tstewart
I have a kscs25inss00
no power on L and N
where do i check for power next
#59 Posted : 14 years ago
no power on L and N
Was the "on-off" switch on the right side on at the test time?
Remove the ice maker. Remove the ice maker harness from the ice maker and check the black wire for continuity. If there is no continuity, replace the whole ice maker.
- The ice maker Part number: AP3182733
tstewart
#60 Posted : 14 years ago
tstewart
Yes it was
Since then I ordered ice maker installed making ice again.
Must have been problem in ice maker unit, still dont no why I didnt have 120v
25 Pages«<45678>»
