jkitchen21
#1 Posted : Sunday, December 7, 2008 3:51:39 PM(UTC)
jkitchen21
We have no water coming out at the start of the cycle. I checked the water line, no leaks. I also re-booted by shutting of the breaker for over one minute.
Thanks for the help.
#2 Posted : Monday, December 8, 2008 12:39:21 PM(UTC)
Remove the dome float (in the front left corner) and check if the float is moving freely up and down and it is not stuck in the upper position.
Remove the toe panel. Check the float switch (under the float) for continuity. It should be closed when the float is in the bottom position.
Remove the wires from the water inlet valve and check the water valve solenoid for continuity. Replace the water inlet valve if it's open.
Check for 120VAC to the water valve while the control calls for water and the float switch is closed.
Post the results.
jkitchen21
#3 Posted : Monday, December 8, 2008 6:20:14 PM(UTC)
jkitchen21
Checked the float, and is had some slight debris. Once cleaned, it worked like a usual!
The help was so good, I was able to get your info to my wife (I'm out of town) and she was actually able to do it.
Thanks again for your help!
Regards,
JK:)
#4 Posted : Monday, December 8, 2008 6:36:17 PM(UTC)
You are welcome. Happy Holidays!
Guest (4)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
Water dispenser not working hums but no water. (Refrigerator & Freezer Repair)
by mouse51180 4/5/2019 4:44:02 PM(UTC)
PULL to start: no water. PUSH to stop: WATER! (Washer Repair)
by gatsby 6/16/2011 7:12:51 PM(UTC)
Whirlpool ED5SHA. Ice in door, but no water. (Refrigerator & Freezer Repair)
by mqqn 1/30/2011 4:52:33 PM(UTC)
GE Refrigerator ice but no water... (Refrigerator & Freezer Repair)
by jxderezi 10/17/2010 3:49:02 PM(UTC)
No touch panel lights, no ice, no water..GE side by side (Refrigerator & Freezer Repair)
by 6tramps 8/21/2010 9:24:14 AM(UTC)
Ge Profile Fridge, lights blinking, thaed out, no ice & no water. (Refrigerator & Freezer Repair)
by WSJR1 12/15/2009 12:05:42 PM(UTC)
S/S Kenmore Refridgerator no water. (Refrigerator & Freezer Repair)
by ChrisMNS.Ut 8/15/2009 9:09:33 PM(UTC)
No Water... (Dishwasher Repair)
by wendyD 7/21/2009 5:52:30 AM(UTC)
