G.E. refrigerator PSS26SGRESS makes ice cubes but does't dispense them and the water stop dispensing through the door? I pulled off the hose at the bottom of the door and pushed the water dispenser and nothing I also changed the filter. Any help would be greatly appreciated Thanks
Do the lights on the display dim when trying to get ice or water? If so, you need a new main control board.
the lights don't dim they go out when you push in on the dispenser arm Thanks
You need a new main control board, Part# WR55x10656
Thank-You for the information the more I am reading I am finding out they have several problems with these boards.
I have a G.E. Profile Arctica Refrigerator...model # PSS26MGTA BB and Serial # DL4256 14 is this also the control board I need? If not could you give me the correct part number.
Could you also include any trade secrets I may need for installation.
Thanks, R.T.
Where is the control board how to check it and how to get to it safely thanks rob
Originally Posted by: rmcclellan  Where is the control board how to check it and how to get to it safely thanks rob Rob, The control board is located in the rear of the fridge lower right hand side. The cover is held on by about 10 1/4 inch hex head screws. As far is I know there isn't a way to trouble shoot this board. It should only take about 15 minutes to change the board. I can now change a board in less then 10 minutes now, I have changed six boards so far; my neighbors and I moved in at the same time and the boards begin to fail about the same time. Make sure the plug is pulled and the only tool you need is a quarter inch nut driver and maybe a sharpie to mark the connections.
