gtkeith
#1 Posted : Saturday, December 6, 2008 4:21:39 PM(UTC)
gtkeith
G.E. refrigerator PSS26SGRESS makes ice cubes but does't dispense them and the water stop dispensing through the door? I pulled off the hose at the bottom of the door and pushed the water dispenser and nothing I also changed the filter. Any help would be greatly appreciated
abadfish66
#2 Posted : Saturday, December 6, 2008 7:59:08 PM(UTC)
abadfish66
Do the lights on the display dim when trying to get ice or water? If so, you need a new main control board.
gtkeith
#3 Posted : Sunday, December 7, 2008 6:59:05 AM(UTC)
gtkeith
the lights don't dim they go out when you push in on the dispenser arm
abadfish66
#4 Posted : Sunday, December 7, 2008 2:40:21 PM(UTC)
abadfish66
You need a new main control board, Part# WR55x10656
gtkeith
#5 Posted : Sunday, December 7, 2008 2:55:33 PM(UTC)
gtkeith
Thank-You for the information the more I am reading I am finding out they have several problems with these boards.
rtelec
#6 Posted : Monday, December 22, 2008 10:02:08 AM(UTC)
rtelec
I have a G.E. Profile Arctica Refrigerator...model # PSS26MGTA BB and Serial # DL4256 14 is this also the control board I need? If not could you give me the correct part number.
Could you also include any trade secrets I may need for installation.
Thanks, R.T.
rmcclellan
#7 Posted : Tuesday, August 18, 2009 9:22:20 AM(UTC)
rmcclellan
Where is the control board how to check it and how to get to it safely thanks rob
rtelec
#8 Posted : Tuesday, August 18, 2009 12:10:37 PM(UTC)
rtelec
Rob, The control board is located in the rear of the fridge lower right hand side. The cover is held on by about 10 1/4 inch hex head screws. As far is I know there isn't a way to trouble shoot this board. It should only take about 15 minutes to change the board. I can now change a board in less then 10 minutes now, I have changed six boards so far; my neighbors and I moved in at the same time and the boards begin to fail about the same time.
Make sure the plug is pulled and the only tool you need is a quarter inch nut driver and maybe a sharpie to mark the connections.
Guest (5)
