dansimpkins
#1 Posted : 14 years ago
dansimpkins
I get the FL error after doing a regular wash. The machine won't fully empty and I can only reset the machine by pulling the plug and then hitting cancel. This fix is intermittent. Can someone help me troubleshoot this problem.
sidfink43
#2 Posted : 14 years ago
sidfink43
Sounds like the control unit, but use this manual to check things out
https://secured.whirlpoo...c5d004632a4?OpenDocument
dansimpkins
#3 Posted : 14 years ago
dansimpkins
thanks for the help!! - i went through the manual and wonder if the OPR or FLD pressure switches could be the culpret? Do you think there is any chance of that? Regards, dan
sidfink43
#4 Posted : 14 years ago
sidfink43
With this model it can be anything, but you will have to try changing out parts to find the problem.
dansimpkins
#5 Posted : 14 years ago
dansimpkins
To those reading this thread - using the manual I methodically tested all the parts in the chain. In the end, it was the drain pump. It was beginning to be intermittent and finally failed completely during the diagnostic process. I replaced the pump and everything works. No need to replace the control board.
sidfink43
#6 Posted : 14 years ago
sidfink43
Great, glad you got it fixed and thanks for updating us.
FL Error Code, Door Latch Stuck Closed (Washer Repair)
by buccolts 15 years ago
