Unit displays an FL error code. Door Locked display light is not on, but can not open door. There are clothes in the washer. Is there a manual latch release, and how can I get to it, to at least get the clothes out. Then, is this a part I can replace myself?
There is a manual pull to unlock the door. You access it by removing the dispenser cover/bezel. The service manual will show you how to do some trouble shooting. Note the section on your model is in an Addendum at the back of the manual. http://www.servicematters.com/m...ibrary/docs/16010061.pdf
