unit blowing cold air. do you have a service manual for this unit.
Originally Posted by: mrfixit3  unit blowing cold air. do you have a service manual for this unit. can anyone help.
I have the same dryer same problem.I figure its probably the heat element but I can't figure out how to get at it.I took off the top and removed screws from top of front control panel but cant get it off.Do you know how to disassemble it.Thanks
Hi,if your still looking for info let me know I just took out my heating element on Inglis yied7200tw.
Wonder if you could help me? I have an inglis yied7200 as well that will not heat. At first I thought it was the burnt contacts on the plug and melted wall socket, but I have replaced them both and still no heat. Any suggestions what to do or test next? Thanks.
