nemecj
#1 Posted : Monday, June 27, 2011 12:48:18 PM(UTC)
nemecj
The washer will progress through the normal cycle, fill and drain but will not agitate or spin. Approximately 2 months ago I replaced the control board because the washer would not spin. After replacement of the board it worked great for approximately one months; and now the motor will not operate. The belt and motor have less than 50 operating hours.
Thanks for yor assist.
jn
sidfink43
#2 Posted : Wednesday, June 29, 2011 5:44:33 PM(UTC)
sidfink43
Well whatever caused your control unit to fail may have caused it to fail again, but I would first check and replace the speed/motor control board and check the door lock mechanism. Those are the two likely sources of your problem.
Washer will not spin or agitate (Washer Repair)
by larrylyons 9/7/2013 1:11:10 PM(UTC)
GE washer will not spin or agitate (Washer Repair)
by tarzandude43 12/18/2012 9:05:54 PM(UTC)
Kenmore 70 series washer will not spin or agitate (Washer Repair)
by boseman75 8/5/2012 2:45:56 PM(UTC)
by Mike442 5/13/2012 11:32:49 AM(UTC)
Maytag style top loading washer will not spin or agitate (Washer Repair)
by Mike442 5/10/2012 6:20:11 PM(UTC)
Washer will not spin or agitate, but fills & drains (Washer Repair)
by Bama Girl 3/3/2012 8:08:41 AM(UTC)
by Jaosn 9/21/2011 5:42:03 AM(UTC)
Washer will not spin or agitate, but drains (Washer Repair)
by coaner 5/17/2011 11:17:09 AM(UTC)
Ge washer will not spin or agitate (Washer Repair)
by Paul Di 3/25/2011 3:02:25 PM(UTC)
by Legatus 11/25/2010 4:44:37 PM(UTC)
by bfreeman91080 1/13/2010 9:15:50 AM(UTC)
by negron 1/10/2010 1:14:57 PM(UTC)
GE Washer will not spin or agitate (Washer Repair)
by casshley 11/6/2009 6:00:06 AM(UTC)
by frankie15oct 7/6/2009 2:22:08 PM(UTC)
by sjjohnson 3/21/2009 10:06:00 AM(UTC)
