frankie15oct
#1 Posted : Monday, July 6, 2009 2:22:08 PM(UTC)
frankie15oct
Cannot get this washer to spin or agitate. After much searching I came to one common answer...The lid switch. I tried bypassing/jumping the lid switch to see if this was the problem but, no luck. Washer drains and fills fine. I cannot her a timer switch between drain and spin cycles and this model has a circuit board behind the mode select knob. Any help would be greatly appreciated. I'm a novice at best when it comes to washers. Thanks
applianceman
#2 Posted : Monday, July 6, 2009 3:23:17 PM(UTC)
applianceman
With the front panel off look to the right of the tub at the top, you should see wires covered with tape. Remove the tape and you should see a red and white wire and on that wire there is a fuse. This is probably your problem the only thing is that you have to cut the wires to test it, be sure to unplug it before doing so. You can test it with an ohmmeter or you can by-pass it but I do not recommend leaving it by-passed this is only for testing. HydroWave GE Washer Repair Guide
frankie15oct
#3 Posted : Monday, July 6, 2009 4:31:10 PM(UTC)
frankie15oct
I found my problem was the computer needed resetting but, the cause was the tubs severly out of balance and the inner tub seems excessivly loose. trying to remove the agitator but, no luck. wanted to check inner tub retaining bolts. any help would be appreciated
frankie15oct
#4 Posted : Monday, July 6, 2009 5:21:19 PM(UTC)
frankie15oct
I got it fixed finally. The retaining nut for the inner tub had come loose. The eratic and violent shaking during the spin cycle caused the computer to go into protective mode and shutdown. Once I figured out how to reset the fault in the computer I could diag. the problem with the tub. Problem fixed. Thank You for your reply:)
Washer will not spin or agitate (Washer Repair)
by larrylyons 9/7/2013 1:11:10 PM(UTC)
GE washer will not spin or agitate (Washer Repair)
by tarzandude43 12/18/2012 9:05:54 PM(UTC)
Kenmore 70 series washer will not spin or agitate (Washer Repair)
by boseman75 8/5/2012 2:45:56 PM(UTC)
by Mike442 5/13/2012 11:32:49 AM(UTC)
Maytag style top loading washer will not spin or agitate (Washer Repair)
by Mike442 5/10/2012 6:20:11 PM(UTC)
Washer will not spin or agitate, but fills & drains (Washer Repair)
by Bama Girl 3/3/2012 8:08:41 AM(UTC)
by Jaosn 9/21/2011 5:42:03 AM(UTC)
by nemecj 6/27/2011 12:48:18 PM(UTC)
Washer will not spin or agitate, but drains (Washer Repair)
by coaner 5/17/2011 11:17:09 AM(UTC)
Ge washer will not spin or agitate (Washer Repair)
by Paul Di 3/25/2011 3:02:25 PM(UTC)
by Legatus 11/25/2010 4:44:37 PM(UTC)
by bfreeman91080 1/13/2010 9:15:50 AM(UTC)
by negron 1/10/2010 1:14:57 PM(UTC)
GE Washer will not spin or agitate (Washer Repair)
by casshley 11/6/2009 6:00:06 AM(UTC)
by sjjohnson 3/21/2009 10:06:00 AM(UTC)
