paulpoll2000
#1 Posted : Saturday, November 29, 2008 2:03:04 PM(UTC)
paulpoll2000
Dryer runs but produces very little heat. It runs continuously. Change timer but this does not seem to be the problem
libertyappl
#2 Posted : Sunday, November 30, 2008 6:11:13 AM(UTC)
libertyappl
Start by checking your household breaker by turning it off then back on. Test the dryer again. If that doesn't work then continue with the below.
Remove the rear panel and test the thermostats and element for continuity.
Post your results.
Nat
kayakcrzy
#3 Posted : Sunday, November 30, 2008 6:41:39 AM(UTC)
kayakcrzy
How about replaceing the coils on the gas valve. If you first turn the dryer on, and it gets hot, then after that, you won't get much heat at all. It is most likely the secondary coil on the gas valve. Tom ApplianceEducator.com
paul (Washer Repair)
by paulmaureen 3/6/2013 10:18:55 AM(UTC)
paulknowlton (Oven Repair (including Ranges and Cooktops))
by paulknowlton 1/10/2011 11:01:19 AM(UTC)
Paulb (Oven Repair (including Ranges and Cooktops))
by revdocpob 12/1/2010 12:39:01 PM(UTC)
Paul M (Washer Repair)
by Paul M 9/28/2010 6:53:32 PM(UTC)
by Paul M 9/28/2010 6:52:00 PM(UTC)
Paul Heinevetter (Oven Repair (including Ranges and Cooktops))
by Paul Heinevetter 7/21/2010 10:45:17 AM(UTC)
Paula (Dishwasher Repair)
by fastball9 6/14/2010 12:50:30 PM(UTC)
Paul McGrath (Washer Repair)
by Paul McGrath 1/14/2010 10:48:48 AM(UTC)
Paulchuk (Washer Repair)
by PAULCHUK 10/22/2009 3:41:30 PM(UTC)
Paul (Refrigerator & Freezer Repair)
by Paul D. Ream 6/26/2009 10:59:00 AM(UTC)
Leslie r. Paulk Jr (Refrigerator & Freezer Repair)
by Leslie Paulk Jr. 8/25/2008 9:54:29 AM(UTC)
