Can anyone send me the installation diagram (instructions) for the dual burner switch, part # 12002125? When I pulled the front panel two of the wires came off before I could tag them. . And I'm not sure which terminal they go on. The switch tested ok but I can't re-install it. Also, this part shown your web site comes with two jumper wires, and the diagram shows one going to terminal P1, but, there were no jumper wires connected to the switch I tested.
Sorry, I should have been more specific. I need to know what wires, red,blck, etc., go on what terminals on the back of the switch.
Paul,
All this information is on the wiring diagram.
Which wires (by the colors) are disconnected and which terminals are without wires?
Gene: Thanks for taking the time to help me out. I have a copy of the wiring diagram but it doesn't translate to the switch I have. In the diagram all the terminals are numbered 1-5. But my switch uses S1,S2,P1,P2, and 2,3,4.
Gene. You did not answer this question yet. Gene.
