ssOur new washer suddenly does not spin out. I assume that it should spin fast like a convintional machine. Ours just sloches back amd forth. Help please or my wife will hang me out to dry!
Paul Take off the front by inserting a screw driver in the gap between the top and front near the edges and releasing the clips that hold the front on. You now want to look at the motor to see if you have flashing lights. Use this guide to trouble shoot if you do, but the first thing you should try is to reset the inverter using the directions in the site. HydroWave GE Washer Repair Guide
Paul M
(Washer Repair)
by Paul M
9/28/2010 6:53:32 PM(UTC)
Paul McGrath
(Washer Repair)
by Paul McGrath
1/14/2010 10:48:48 AM(UTC)
