207 Pages«<2021222324>»
imref
#211 Posted : Monday, November 17, 2008 9:32:44 PM(UTC)
imref
Gene, thanks for the response - so the fan would come on in the diagnostic mode even if it is bad? I'll go ahead and replace it and see what happens.
imref
#212 Posted : Thursday, November 20, 2008 1:50:02 PM(UTC)
imref
Most likely the evaporator fan motor is bad. Hopefully it did not damaged the new main control board. The new fan motor comes together with the thermistor so you can replace them both.
- The part number for the evaporator fan motor with the thermistor is AP3191003
Hi Gene, I ordered the fan motor you suggested, it was identical to the one I had except the part # above had the built in thermistor (yes, I know I should have checked before ordering). I went ahead and installed it anyway. It seems to have fixed the problem as the evaporator fan is now working.
Will the fact that I now have a thermistor attached to my fan motor that I didn't have before cause any problems?
Thanks!
mwmurphy
#213 Posted : Monday, November 24, 2008 11:38:12 AM(UTC)
mwmurphy
Fridgidaire FRS24WRC Side by Side
Condensor seems to run all the time. No frost in Freezer, Some airlow in upper frig vent but no air flow in lower chilled meats drawer. Coils are clean and I can see any blockage on te lower drawer vent. Sound like the same problem?
#214 Posted : Tuesday, November 25, 2008 10:42:48 AM(UTC)
imref,
I'm afraid I did not get it clear. What did you do with the thermistor which came with the motor?
#215 Posted : Tuesday, November 25, 2008 10:54:50 AM(UTC)
Originally Posted by: mwmurphy Go to Quoted Post
...Coils are clean...
Which coils did you mean? The evaporator coils normally should be about 100% covered with light snow. If there is no snow then there is a problem with the sealed system. It could be low on Freon.
Here are the break down diagrams for the Frigidaire refrigerator Model FRS24WRCD0
imref
#216 Posted : Tuesday, November 25, 2008 11:11:54 AM(UTC)
imref
Hi gene, it was hard-wired into the fan motor plug, so I just left it alone. I didn't cut it off. Do I need to worry about it at all? The fridge has worked great for several days now.
mwmurphy
#217 Posted : Tuesday, November 25, 2008 3:52:58 PM(UTC)
mwmurphy
Freezer coils are frosty, I was talking about the coils underneath.
#218 Posted : Tuesday, November 25, 2008 4:04:42 PM(UTC)
Did you see another thermistor on top of the evaporator coil? If you did, how it was connected?
#219 Posted : Tuesday, November 25, 2008 4:14:14 PM(UTC)
Did you open the damper (#66 on the break down diagram) for the meet keeper drawer?
imref
#220 Posted : Tuesday, November 25, 2008 4:23:40 PM(UTC)
imref
I didn't, but to be honest I didn't look all that hard for one.
Guest (11)
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
