goffer9
#1 Posted : Tuesday, November 25, 2008 6:12:39 AM(UTC)
goffer9
I have a gas dryer that fires up stays lit for about 3 to 4 minutes then shuts off. It then tries to refire ( you can see the glow of the igniter) but it won't light. If I unplug it and start over it does the same thing. I was wondering if it could be the thermal fuse or could it be the flame sensor?
#2 Posted : Tuesday, November 25, 2008 1:43:13 PM(UTC)
Most likely the problem is a bad gas valve coil. If you need the right part number - post the complete model number of the dryer.
goffer9
#3 Posted : Friday, November 28, 2008 2:52:29 AM(UTC)
goffer9
Thanks Gene for your help. You were right once I changed the coil it was working like a charm.
#4 Posted : Friday, November 28, 2008 11:00:33 AM(UTC)
I'm gad you were able to fix it.
Guest (4)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
