Please help!
Washer not spinning with water still in the washer. Light indicator on: Wash, and Door Lock.
The washer was able to pump out water when I move the timer close to final spin section. Still, won't spin. I opened the back and found the belt in excellent condition. Spin the motor w/ bell in place by hand and it spin o.k. so motor and tub spins freely by hand.
Found a 12A fuse on the circuit board on bottom left of the washer and tested it with multimeter. It is open. Thinking I found the solution so I purchased a new fuse replaced the 12A fuse and tried out the spin cycle. Still no spin, no sound. Tested the fuse and it is open again. Some thing is drawing a lot of amps!!
Took the motor out and found 6 conductors coming out of the motor. One ground, two small white (Tach), one black, one blue, and one red.
Hoping the motor is not a 3 phrase type motor, I energized the black and red, and later black and blue. Motor spins either case. I used a clamp type A/C multimeter and measure the current. They came out to be around 10 amps and 11 amps for the two differnent connections.
Is it normal to have such high current without load?
I have not checked the door switch because I don't know how to get to it, yet.
Any help is appreciated.
Thanks in advance.
APPLU
Just checked the washer without the motor connected, the 12A fuse still burns out. :(
It may not be the motor?
I look inside the washer and don't see any wires pinched. The controller circuit board looks good, no obvious signs of burnt.
Took out the door lock switch and tested. PTC works (interesting, it works like a solenoid) , relay works, continuity works when relay energized.
Only two more items that can be wrong? Controller circuit board and timer?
Anyone have any comments?
Don't know what to test the timer.
