kimbovia
#1 Posted : Tuesday, May 31, 2011 6:40:01 AM(UTC)
kimbovia
I have a second hand Kenmore washer that suddenly will not stop filling. I have been waiting for it to fill and have turn the water off then manually turn the control knob to the next cycle. Is this a stuck valve or broken valve? It even fills when it's off.
Thanks for any help
kimbovia
sidfink43
#2 Posted : Wednesday, June 1, 2011 8:58:43 AM(UTC)
sidfink43
If it is happening when the machine is off then the valves are stuck open. Change them out and that should fix things nicely.
Washer won't stop filling (Washer Repair)
by sundbergjc 3/5/2018 8:16:31 AM(UTC)
by bombay71 5/27/2017 2:19:25 PM(UTC)
GE washer won't stop filling, agitate or spin (Washer Repair)
by nmoreno24 10/14/2016 6:57:55 PM(UTC)
by pfeffern 10/19/2014 4:32:07 PM(UTC)
maytag washer won't stop filling up (Washer Repair)
by aswright33 7/13/2014 11:15:42 AM(UTC)
GE Washer won't stop filling even after replacing Water Level Switch (Washer Repair)
by ctvquach 1/12/2014 4:33:29 PM(UTC)
washer won't stop filling (Washer Repair)
by Becki Meek 12/27/2012 11:54:31 AM(UTC)
Maytag Washer won't stop filling (Washer Repair)
by wjpcohen 5/21/2012 9:11:31 AM(UTC)
Kenmore Elite Washer won't stop filling on cold cycles (Washer Repair)
by pgast2 4/1/2012 4:47:22 PM(UTC)
Frigidaire Washer Won't Stop Filling Up (Washer Repair)
by hntpilcher 2/23/2012 12:59:23 PM(UTC)
Maytag Washer Won't Stop Filling (Washer Repair)
by klunker 7/26/2011 10:26:38 AM(UTC)
by craigwebster375 7/25/2011 3:23:21 PM(UTC)
whirlpool washer won't stop filling (Washer Repair)
by magicLV 7/12/2011 1:08:23 PM(UTC)
by alohatech 5/18/2011 12:32:33 AM(UTC)
Washer won't stop filling up (Washer Repair)
by CarlaS 2/22/2011 7:50:19 AM(UTC)
