feinerl
#1 Posted : Sunday, October 21, 2007 6:32:37 PM(UTC)
feinerl
I moved into a house that has two units CT130 lectiric oens. One works fine but eh other will not heat up properly. NO error code comes up but it wont get hot. It begins to warm up and a fan comes on. If I try to increase the set temp sometimes it just shuts down. I have done a reset at the breaker to no avail. ANy ideas?
feinerl
#2 Posted : Monday, October 22, 2007 4:21:44 AM(UTC)
feinerl
After playing with it a buit longer, I got the E6 error code which I think means the selector switch is bad. Does this sound correct before I try ordering the part?
sambledsoe
#3 Posted : Saturday, December 22, 2007 12:01:00 PM(UTC)
sambledsoe
I have had the same oven since new in 1993 and this symptom has occurred several times. Each time I replace the switch and it works for a year or so. After setting the temperature, the "heat" light will not come on. If I kick the panel adjacent to the switch very hard, the light will come on and the oven will heat. However I have injured my knee kicking the oven so have just ordered another switch assembly for the 4th time. The small phosphor-bronze fingers in the rear wafer of the switch assembly appear to lose their tension and make erratic contact with the circuit board, prompting the "Error E6" code. I have tried to repair the board by cleaning and re-tensioning the fingers, but with limited success. Good luck!
--sam bledsoe
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
Frigidaire GLEF378CBD - oven not heating (Oven Repair (including Ranges and Cooktops))
by canooten 3/20/2020 11:24:19 AM(UTC)
by deanowhitney 7/11/2018 11:22:38 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Oven not heating when using convection (Oven Repair (including Ranges and Cooktops))
by ebonyclose 3/11/2018 7:37:25 PM(UTC)
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
Upper oven not heating, lower over works properly (Oven Repair (including Ranges and Cooktops))
by Greg2cycle 11/5/2016 9:50:34 AM(UTC)
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Whirpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by cdfrerichs01 8/7/2016 10:55:06 AM(UTC)
