brianv
#1 Posted : Sunday, October 21, 2007 12:50:27 PM(UTC)
brianv
When washer is switched on, it begins agitating as if it was full of water. No water is taken on at all. The washer worked fine the previous day with no indication of problems.
jdappl07
#2 Posted : Wednesday, October 24, 2007 8:05:58 PM(UTC)
jdappl07
there is a pressure switch in the controls which choses the size of the load and amount of water. Take the clear hose going down the side of the tank off and blow in it if you hear a clicking noise there is something in the dome on the side if the tank if not you need a pressure switch
Washer doesn't fill or spin, but will agitate and drain. (Washer Repair)
by Guest 7/9/2023 6:21:45 PM(UTC)
Dishwasher Doesn't Fill For Rinse Cycle. (Dishwasher Repair)
by JMsnh 11/5/2018 6:27:57 AM(UTC)
Washer doesn't fill. (Washer Repair)
by twmayes 3/26/2011 10:01:05 AM(UTC)
washer doesn't fill with water (Washer Repair)
by cla 2/5/2008 6:42:08 PM(UTC)
