Debra Carlin
#1 Posted : Saturday, November 15, 2008 6:04:36 PM(UTC)
Debra Carlin
My husband replaced some lights and when he finished the garbage disposal and the dishwasher were not turning on. We reset the circuit breakers to no avail. I can't find any other reset buttons, does anyone have any ideas?? Thank you.
icehouse
#2 Posted : Sunday, November 16, 2008 9:49:14 AM(UTC)
icehouse
rattrapp
#3 Posted : Monday, November 17, 2008 6:47:46 PM(UTC)
rattrapp
I'm guessing it's a bad circuit breaker. When you turned it off to do the lights it probably died and won't close again. If you replace that breaker (should be 15 amps) you'll likely fix the problem.
icehouse
#4 Posted : Tuesday, November 18, 2008 4:58:19 AM(UTC)
icehouse
Let's not miss inform. :eek: Dishwasher, Garbage Disposal should be on separate 20 Amp Circuit Breakers and wired 12/3. This is by NEC.
Why changing lights would have an effect unless wired together which is not to code. :)
Guest (4)
Possible dryer electrical problem (Dryer Repair)
by Dmillbhawk 8/1/2013 10:43:43 AM(UTC)
Do I have electrical problem? Soap dispenser? (Dishwasher Repair)
by roger20 3/13/2012 3:42:47 PM(UTC)
electrical problem (Oven Repair (including Ranges and Cooktops))
by robertwgeorge 2/9/2012 6:44:19 PM(UTC)
electrical problem (Washer Repair)
by garycart 4/4/2011 4:57:29 PM(UTC)
Electrical problem (Dishwasher Repair)
by capndavid2001 8/31/2010 6:08:08 AM(UTC)
Maytag Dryer - first noise, now also electrical problem (Dryer Repair)
by RobBroekhuis 11/7/2009 2:23:58 PM(UTC)
Electrical problem (Washer Repair)
by hb6306 9/10/2009 12:55:10 PM(UTC)
Icemaker front panel electrical problem (Refrigerator & Freezer Repair)
by ttvor 6/20/2009 2:10:55 PM(UTC)
Electrical problem (Refrigerator & Freezer Repair)
by mcbdallas 2/19/2008 11:27:42 AM(UTC)
