Marcos
#1 Posted : Friday, October 19, 2007 6:33:10 PM(UTC)
Marcos
My lights went out one morning and came back on. (we beleive it was weather related). When I returned from work I noticed the fridge was not as cold as usual. The lights and fan worked. Me being a gueniss (lol) looked under the sheet metal in the back and found the motherboard was burnt and sparking to the touch. Of course I unplugged it after that. I ordered the new motherboard and installed it. My kitchen breaker blew out an hour later. The fridge is like not getting cold at all. Same senerio lights where on and the fan blowing. (no the compressor was not truning on) Oh I already replaced the relay next to the compressor. It was a universal piece. I'm lost now any suggestions?
#2 Posted : Friday, October 19, 2007 7:22:08 PM(UTC)
Hi Marcos
What relay did you replace? What is the part number?
The problem could be a wrong relay or a bad compressor.
If your fridge is less then five years old, the compressor should be under the manufacturer warranty, but the relay is not. And if you used a wrong relay it could void the warranty on the compressor.
#3 Posted : Saturday, October 20, 2007 2:10:15 AM(UTC)
Check for a shorted compressor to ground. If so, it is covered under your warranty.
GE Motherboard (Refrigerator & Freezer Repair)
by Quackula100 7/10/2020 8:24:31 PM(UTC)
New motherboard, now compressor not working (Refrigerator & Freezer Repair)
by Jeanebk 6/19/2020 4:36:51 PM(UTC)
Replace motherboard after power outage. (Refrigerator & Freezer Repair)
by Airjglo 4/2/2020 12:59:06 PM(UTC)
Need help with GE side by side, motherboard model. (Refrigerator & Freezer Repair)
by kctyphoon 3/8/2016 4:13:51 PM(UTC)
Clicking after replacing motherboard (Refrigerator & Freezer Repair)
by ClicknFridge 1/19/2016 5:16:55 AM(UTC)
Replaced motherboard/control board (Dishwasher Repair)
by ambyrlynne 7/1/2015 6:24:37 PM(UTC)
Motherboard has a burn (Refrigerator & Freezer Repair)
by randymarcell 6/11/2015 10:48:44 AM(UTC)
Need help with motherboard connectors GE Profile (Refrigerator & Freezer Repair)
by MadmanArctica 10/23/2014 8:39:22 PM(UTC)
GE Frig Inop - Motherboard? (Refrigerator & Freezer Repair)
by civilized_hillbilly 12/3/2013 2:12:45 PM(UTC)
changing motherboard on ge side-by-side (Refrigerator & Freezer Repair)
by av8or 9/10/2013 2:19:18 PM(UTC)
After replacing motherboard temperature drops to 50 degrees (Refrigerator & Freezer Repair)
by AcuraNC 6/11/2013 1:43:09 AM(UTC)
Not cooling, clicking from motherboard (Refrigerator & Freezer Repair)
by Jcc4507fly 10/8/2012 6:44:32 PM(UTC)
motherboard diagram needed (Refrigerator & Freezer Repair)
by TSCHMELTER 6/19/2012 11:16:22 AM(UTC)
Replacing GE refrigerator evaporator motors and motherboards (Refrigerator & Freezer Repair)
by richappy 5/18/2012 3:06:01 PM(UTC)
change motherboard (Refrigerator & Freezer Repair)
by dhan 2/13/2012 12:29:36 PM(UTC)
