johnp
#1 Posted : 16 years ago
johnp
My dryer is not getting hot. I can't figure out where to look for the problem because when I open it up I don't know what I'm lookig at. Is it possible to find a diagram of what to look for? Any help is appreciated.
v2k04
#2 Posted : 16 years ago
v2k04
Do you have a meter?
johnp
#3 Posted : 16 years ago
johnp
No I don't have a meter, but will get one ,
My problem is that I don't know what I am looking at or what to test without a diagram.
johnp
#4 Posted : 16 years ago
johnp
No but will get one . But i still don't know what i am lookig at without a diagram
v2k04
#5 Posted : 16 years ago
v2k04
We will show you if ya want to learn I look for the easiest thing first. that woulkd be all the thermastats you ohm them all out if you find one open you replace it. or you can remove the wires off each thremastst one by one and black tape them to gether and plug it in and try it if it heats you knoiw that stat is bad the thermastats have 2 wires going to each one one on each side of stat thats the two you join together a thermastat is just a switch like a light switch on the wall when you turn it on its closed when you turn it off its open
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 10 months ago
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 11 months ago
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 2 years ago
Kenmore Gas Dryer wont stay hot (Dryer Repair)
by johnmeyers 4 years ago
Kenmore Gas Dryer - No Heat (Dryer Repair)
by smackover 6 years ago
Kenmore Gas Dryer Timer (Dryer Repair)
by keepitfromthedump 8 years ago
Kenmore gas dryer won' dry clothes all the way (Dryer Repair)
by ggarnett 8 years ago
Kenmore Gas dryer wnot heat (Dryer Repair)
by wardm6 9 years ago
kenmore gas dryer runs only when push to start is pressed in (Dryer Repair)
by carlosjbb 9 years ago
Kenmore gas dryer heats intermittently (Dryer Repair)
by Nordillaca 9 years ago
Kenmore Gas Dryer intermittent (Dryer Repair)
by diyeng 11 years ago
Kenmore Gas Dryer won't Heat (Dryer Repair)
by rboysen 11 years ago
electrolux/kenmore gas dryer fault (Dryer Repair)
by iclad 11 years ago
No heat - Kenmore gas dryer (Dryer Repair)
by Brian Effinger 11 years ago
Kenmore Gas dryer, no heat control (Dryer Repair)
by iowacows 11 years ago
