2 Pages12>
Tomsav31
#1 Posted : Tuesday, May 17, 2011 12:22:31 PM(UTC)
Tomsav31
The problem I'm experiencing is my freezer is freezing and doing what it suppose to do but the refrigerator is not cold.The temperature switch both fill little different when you go to move it to a certain temperature.The temperature shows 71 Degrees for the refrigerator and the freezer shows 0degrees.I'm guessing it can be the thermostat.
#2 Posted : Wednesday, May 18, 2011 1:57:01 AM(UTC)
Your model # will not work. I would check in the freezer for a ice clog at the freezer control flapper in the freezer.
Tomsav31
#3 Posted : Wednesday, May 18, 2011 8:08:44 AM(UTC)
Tomsav31
Where is the freezer control flapper located.Is it located on the thermastat or near it?Do I need to turn down the thermastat to let it defrost?
Tomsav31
#4 Posted : Wednesday, May 18, 2011 8:12:57 AM(UTC)
Tomsav31
  • Originally Posted by: Tomsav31 Go to Quoted Post
    Serial #TZ241710 GE
#5 Posted : Wednesday, May 18, 2011 8:39:34 AM(UTC)
If your control panel is in the back wall of the refrigerator, the control is right in back of it.
Tomsav31
#6 Posted : Wednesday, May 18, 2011 8:46:41 AM(UTC)
Tomsav31
Both controls are in the refrigerator not the freezer.So,it would be behind both controls?
Tomsav31
#7 Posted : Wednesday, May 18, 2011 8:50:32 AM(UTC)
Tomsav31
Do I need to defrost the freezer to make it work?
#8 Posted : Thursday, May 19, 2011 1:47:56 AM(UTC)
If the evaporator is all frosted up, that is your problem. When you take the freezer back panel off, check for ice at the vent to the refrigerator section.
Tomsav31
#9 Posted : Thursday, May 19, 2011 1:40:57 PM(UTC)
Tomsav31
The evaporator is clear.It's not frosted.The air from the freezer is not blowing to the refrigerator at all.No coldnest what so ever.When I move the thermastat for the refrigerator,you do not hear the compresor shut on or off.You can hear for the freezer.
#10 Posted : Friday, May 20, 2011 1:03:36 AM(UTC)
Either your evaporator fan is not working, or you have an ice jam in the bottom fridg section behind the lower crisper drawer.If ok, pull the control panel off and check the vent to the freezer.
Guest (4)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Crosley, model: GS24Y8DV, side by side Refrigerator/Freezer. (Refrigerator & Freezer Repair)
by AeroncaChief 11/9/2022 4:07:46 PM(UTC)
Kenmore Elite side by side refrigerator (Refrigerator & Freezer Repair)
by jfortner 6/18/2022 7:38:51 AM(UTC)
Just bought new side by side refrigerator but doesn't get cold enough (Refrigerator & Freezer Repair)
by Hotlynx16 3/28/2022 2:47:44 PM(UTC)
Admiral side by side refrigerator external drip drain tray (Appliance Parts)
by Paul Bridges 1/14/2021 10:28:34 AM(UTC)
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5/29/2020 5:25:03 AM(UTC)
GE Profile Side by Side Refrigerator Model ESS25XGMB (2001) not cooling (Refrigerator & Freezer Repair)
by boxer 7/14/2019 7:19:21 PM(UTC)
Kenmore side by side refrigerator keep running (Refrigerator & Freezer Repair)
by Xmwwang 2/21/2019 7:14:22 PM(UTC)
side by side refrigerator started clicking and humming (Refrigerator & Freezer Repair)
by mjkneiser 6/28/2018 8:18:44 AM(UTC)
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 6/10/2018 3:21:06 PM(UTC)
Side by side refrigerator keeps turning on and off (Refrigerator & Freezer Repair)
by Rasenganguy 9/27/2016 6:43:34 PM(UTC)
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 2/11/2016 11:59:48 AM(UTC)
Fridge and freezer too warm in my side by side refrigeratorld enough (Refrigerator & Freezer Repair)
by Majdo 9/17/2015 11:52:33 AM(UTC)
Side by side refrigerator not cooling. (Refrigerator & Freezer Repair)
by Jms55 1/26/2015 12:24:12 PM(UTC)
GE side by side refrigerator not holding temperature (Refrigerator & Freezer Repair)
by Jmatthew33 7/8/2014 8:06:56 PM(UTC)
2 Pages12>
