brian16
#1 Posted : Tuesday, November 11, 2008 5:58:29 PM(UTC)
brian16
Have 240 coming in from the box, have continuity at the 2 prong (thermal switch?) by exhaust tube and at the 4 prong unit by exhaust tube and the 2 prong switch at the top of the unit where the heating element is at the bottom. Get nothing from any of the leads that I try on the element-replace the element?
#2 Posted : Wednesday, November 12, 2008 1:52:59 AM(UTC)
Remove one wire from the heating element and measure it for resistance.
Should be approximately 10 ohms.
If open remove the heating element you will probably see where the break is.
Order a new one and replace it.
Remember to unplug the unit while doing this!
kayakcrzy
#3 Posted : Wednesday, November 12, 2008 3:57:57 AM(UTC)
kayakcrzy
Welcome Denman, good to see you, I think you will like it here. Brian have you checked the temp switch up at the console. Sometimes they go out. Tom ApplianceEducator.com
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Speed Queen electric dryer no heat after 5 min. (Dryer Repair)
by napalm747 8/23/2014 6:05:30 PM(UTC)
electric dryer no heat - problem solved (Dryer Repair)
by JohnWMc 6/2/2014 3:17:26 PM(UTC)
Electric dryer no heat (Dryer Repair)
by Timothy Burt 4/10/2014 12:02:47 PM(UTC)
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 10/30/2013 2:38:30 PM(UTC)
whirlpool duet electric dryer no heat (Dryer Repair)
by Reisingera03 2/6/2013 2:49:42 PM(UTC)
by CSteidl 8/14/2012 11:59:05 AM(UTC)
by livetoride2112 3/5/2012 5:24:19 PM(UTC)
Maytag Neptune Electric Dryer No Heat (Dryer Repair)
by jrvier 11/12/2011 3:31:42 PM(UTC)
kenmore electric dryer no heat (Dryer Repair)
by vito m 5/18/2011 6:00:36 PM(UTC)
Sears Galaxy Electric dryer no heat,timer doesn't move (Dryer Repair)
by melindascrochet 5/2/2011 7:38:20 AM(UTC)
Whirpool Electric Dryer No heat (Dryer Repair)
by flmeade 9/14/2010 8:38:15 AM(UTC)
EstateElectric Dryer No Heat (Dryer Repair)
by elaza 6/5/2010 8:00:42 AM(UTC)
by STEVE8369 3/16/2010 3:53:24 AM(UTC)
by MIKEK38E 2/9/2010 5:25:07 AM(UTC)
