Ragwing
#1 Posted : 16 years ago
Ragwing
Roper RAL5144ALO washer won't spin. Water pumps out. Agitator turns slowly during spin cycle, can stop it with my hand.
libertyappl
#2 Posted : 16 years ago
libertyappl
The agitator turns or the tub is turning slowly?
Ragwing
#3 Posted : 16 years ago
Ragwing
Agitator barely turns. Tub stays still.
libertyappl
#4 Posted : 16 years ago
libertyappl
Is it turning in the same direction or actually agitating back & forth?
Ragwing
#5 Posted : 16 years ago
Ragwing
Turns clockwise. Very weak. Ratcheting motion. No discernable counter clockwise motion.
#6 Posted : 16 years ago
Pull the bolt off under the fabric softener, pull the agitator off, and verify the spindle does not agitate, if so, you have a bad transmission or a broken coupler.
Ragwing
#7 Posted : 16 years ago
Ragwing
With the agitator off, the shaft turns clockwise. I can easily stop it with my fingers.
Ragwing
#8 Posted : 16 years ago
Ragwing
I have removed the motor to inspect the coupler. It appears to be in good condition.
Ragwing
#9 Posted : 16 years ago
Ragwing
Have noticed that there is what appears to be a clutch assembly on top of the gearbox. This assembly turns when the timer is set to the "spin" mode. So I assume that the gearbox is ok. Am guessing that perhaps some clutch parts are worn. Need to determine what parts to order.
Ragwing
#10 Posted : 16 years ago
Ragwing
Have removed the gearbox. Noticed that the brake driver cam is broken. Will order a clutch assembly kit. p/n AP3094537
Roper washer won't spin or drain (Washer Repair)
by diy4now 13 years ago
roper washer won't spin (Washer Repair)
by Julie Rogers 15 years ago
Roper washer won't spin (Washer Repair)
by alink 17 years ago
by cheapster 17 years ago
