Ragwing
#1 Posted : Monday, November 10, 2008 9:12:09 AM(UTC)
Ragwing
Roper RAL5144ALO washer won't spin. Water pumps out. Agitator turns slowly during spin cycle, can stop it with my hand.
libertyappl
#2 Posted : Monday, November 10, 2008 9:26:29 AM(UTC)
libertyappl
The agitator turns or the tub is turning slowly?
Ragwing
#3 Posted : Monday, November 10, 2008 10:41:50 AM(UTC)
Ragwing
Agitator barely turns. Tub stays still.
libertyappl
#4 Posted : Monday, November 10, 2008 10:51:30 AM(UTC)
libertyappl
Is it turning in the same direction or actually agitating back & forth?
Ragwing
#5 Posted : Monday, November 10, 2008 11:37:30 AM(UTC)
Ragwing
Turns clockwise. Very weak. Ratcheting motion. No discernable counter clockwise motion.
#6 Posted : Tuesday, November 11, 2008 1:30:22 AM(UTC)
Pull the bolt off under the fabric softener, pull the agitator off, and verify the spindle does not agitate, if so, you have a bad transmission or a broken coupler.
Ragwing
#7 Posted : Tuesday, November 11, 2008 3:15:24 AM(UTC)
Ragwing
With the agitator off, the shaft turns clockwise. I can easily stop it with my fingers.
Ragwing
#8 Posted : Tuesday, November 11, 2008 4:33:19 AM(UTC)
Ragwing
I have removed the motor to inspect the coupler. It appears to be in good condition.
Ragwing
#9 Posted : Tuesday, November 11, 2008 5:01:36 AM(UTC)
Ragwing
Have noticed that there is what appears to be a clutch assembly on top of the gearbox. This assembly turns when the timer is set to the "spin" mode. So I assume that the gearbox is ok. Am guessing that perhaps some clutch parts are worn. Need to determine what parts to order.
Ragwing
#10 Posted : Tuesday, November 11, 2008 5:51:54 AM(UTC)
Ragwing
Have removed the gearbox. Noticed that the brake driver cam is broken. Will order a clutch assembly kit. p/n AP3094537
Guest (4)
Roper washer won't spin or drain (Washer Repair)
by diy4now 1/22/2012 6:08:35 AM(UTC)
roper washer won't spin (Washer Repair)
by Julie Rogers 4/23/2010 1:58:42 PM(UTC)
Roper washer won't spin (Washer Repair)
by alink 7/20/2008 4:08:42 PM(UTC)
by cheapster 3/12/2008 11:03:45 AM(UTC)
