lvsheridan
#1 Posted : Thursday, May 5, 2011 3:40:30 PM(UTC)
lvsheridan
Microwave is part of oven microwave combo. The oven works but the microwave has no power at all. How do I troubleshoot the microwave?
Joe / APP Team
#2 Posted : Friday, May 6, 2011 8:30:21 AM(UTC)
Joe / APP Team
Iv,
You're sure the oven works, including the oven elements ? you may have lost a L1 or L2 power leg, you may want to reset the breakers for the oven (several times).
Your basic indications would indicate,
An open "in line" fuse, located behind the microwave control panel, on the base of the M/W.
An open Magnetron Thermal fuse, mounted to the Magnetron Tube, you may be able to reach and test it once the control panel is down, it'll be "tight" but doable.
An open Cavity Thermal fuse, mounted on the back wall of the microwave, you'll have to remove the oven from the cabinet, remove the top, right side and back panels to access it.
Let's hope it's the in line fuse.
lvsheridan
#3 Posted : Friday, May 6, 2011 12:05:30 PM(UTC)
lvsheridan
I have reset the oven breaker several times with no result. The oven and its cooking elelments are fully functional. My problem is that I can't figure out how to get the control panel off? I removed the cover where the fan and light are but could not find a fuse. I then tried to figure out how to get the paenl off but I am stumped? Thanks for yor help
Originally Posted by: Joe / APP Team Go to Quoted Post
Iv,
Joe / APP Team
#4 Posted : Friday, May 6, 2011 1:33:47 PM(UTC)
Joe / APP Team
IV,
There's not a lot of information on this unit, I'm a little limited.
Try this,
Open the M/W door and look in the door side of the control panel, there should be 2 screws holding the panel to the front flange of the microwave.Remove the screws and push up on the bottom of the panel, and pull out on the top of the panel. it should unlatch itself, and you'll be able to slowly, carefully move the assembly and access the fuse and control assembly.
:cool: :cool: :cool:
KitchenAid Microwave Does Not Start (Microwave Repair)
by chris75799 7/5/2016 4:06:32 PM(UTC)
Kitchenaid Microwave not working (Microwave Repair)
by rprprp 11/5/2012 7:15:09 AM(UTC)
KitchenAid microwave (Microwave Repair)
by RayM 7/20/2012 12:10:35 PM(UTC)
Kitchenaid microwave keeps beeping (Microwave Repair)
by rfkjerslk 11/1/2011 3:50:15 PM(UTC)
Kitchenaid Microwave - Error F7. Help!! (Microwave Repair)
by Klavman 3/15/2011 9:43:55 AM(UTC)
KitchenAid microwave turns on when door is openned (Microwave Repair)
by barberd 11/11/2010 4:32:19 PM(UTC)
KitchenAid Microwave Disassembly Procedure (Microwave Repair)
by Triode Pete 11/7/2010 8:52:03 AM(UTC)
KitchenAid Microwave F2 Error and more (Microwave Repair)
by lholmes11 11/4/2010 11:41:38 AM(UTC)
Kitchenaid microwave hood fan combo (Microwave Repair)
by rjmo_bourque 9/22/2009 2:44:11 PM(UTC)
KitchenAid Microwave Hood combo (Microwave Repair)
by GGman 7/22/2009 6:58:20 PM(UTC)
Kitchenaid Microwave No Power (Microwave Repair)
by joe-doggs 5/16/2009 7:53:37 AM(UTC)
kitchenaid microwave flashing : (Microwave Repair)
by hal100 4/24/2009 4:30:12 PM(UTC)
Kitchenaid microwave access to magnetron (Microwave Repair)
by stakenborg 4/22/2009 12:19:44 PM(UTC)
Kitchenaid microwave runs but won't heat (Microwave Repair)
by ladymay65 3/27/2009 10:41:48 PM(UTC)
Transformer replacement forKitchenaid Microwave KHMS155LSS4 (Microwave Repair)
by tennisman 11/20/2008 4:47:18 PM(UTC)
