Gpa
#1 Posted : Thursday, April 28, 2011 12:12:30 PM(UTC)
Gpa
already replaced sseal, but freezer still won't freeze anything except ice cubes. what do I try next?:rolleyes:
#2 Posted : Friday, April 29, 2011 3:21:34 AM(UTC)
Replacement parts for KENMORE 1068698210 | AppliancePartsPros.com
Find out if the compressor is running and is it cycling on/off.
You can usually hear them when they are on also you should be able to feel ie vibrating and it should be warm.
If it is cycling it is probably a thermostat problem.
Since it is cooling some I doubt it is always off.
If it is always on, remove the rear cover in the freezer so you can see the coils.
If they are heavily iced/frosted over you have a defrost problem.
It could be the timer, the heater or the defrost thermostat.
Get back to us for how to check these.
If there is only frost in one area (usually where the freon enters the coils) you are low on freon. This will be an expensive repair and usually it makes more sense to replace the unit.
Note: That this is a sealed system problem so check your warranty as the sealed system often has a warranty longer than one year.
Whirlpool Top-Mount Freezer won't freeze (Refrigerator & Freezer Repair)
by Regalhank 11/29/2016 6:58:46 AM(UTC)
Freezer won't freeze after advancing defrost timer (Refrigerator & Freezer Repair)
by MightySky 7/8/2013 7:33:03 PM(UTC)
Upright Freezer won't freeze and makes loud noise (Refrigerator & Freezer Repair)
by Renatefry 2/20/2013 5:15:25 PM(UTC)
by Renatefry 2/20/2013 5:02:07 PM(UTC)
by shoman 3/24/2012 6:36:59 AM(UTC)
Freezer won't freeze, fridge not that cold (Refrigerator & Freezer Repair)
by otison 1/28/2012 10:26:29 AM(UTC)
frigidaire freezer won't freeze an fridge isn't cold as should be. (Refrigerator & Freezer Repair)
by auralight1 1/22/2012 8:07:33 AM(UTC)
by duncanj 10/30/2011 7:16:33 AM(UTC)
Fridge Cold, Freezer won't freeze all the time (Refrigerator & Freezer Repair)
by darrellwass 10/21/2011 6:59:02 AM(UTC)
Freezer Won't Freeze, Both Sides Stuck at @ 40ยบ (Refrigerator & Freezer Repair)
by obx166ec 10/7/2011 3:53:35 PM(UTC)
Refrigerator freezer won't freeze (Refrigerator & Freezer Repair)
by bittersweet 12/16/2010 10:53:30 AM(UTC)
Freezer Won't Freeze (Refrigerator & Freezer Repair)
by leichte 11/10/2010 3:13:48 AM(UTC)
by blancapaloma5290 8/13/2010 11:42:02 AM(UTC)
freezer won't freeze anymore (Refrigerator & Freezer Repair)
by 1967hammer 9/6/2008 7:56:26 AM(UTC)
HotPoint Refrigerator's Freezer won't freeze (Refrigerator & Freezer Repair)
by RHCHomeowner 7/18/2008 7:02:39 PM(UTC)
