Paddlinpaul
#1 Posted : Wednesday, November 5, 2008 5:17:58 PM(UTC)
Paddlinpaul
I went to unload my dishwasher tonight and the bottom was full of water. I ran the rinse cycle again to see if it would drain and it ended up with more water in it. The motor sounded like it engaged and ran through the rinse cycle. I shut off the circuit breaker, siphoned out all the water and removed the front panel. I am not sure what to look for next.
magician59
#2 Posted : Thursday, November 6, 2008 5:50:07 AM(UTC)
magician59
First check to see if there is a kinked or restricted drain hose. Could also be clogged. Does the sink drain freely? Next, you should check the pump for obstruction or operation. This may need to be done by a qualified technician.
abadfish66
#3 Posted : Thursday, November 6, 2008 6:02:44 AM(UTC)
abadfish66
Does it drain into the garbage disposer, or do you have an airgap at the sink, if airgap, check for a clog there
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Dishwasher will not drain at end of cycle ... (Dishwasher Repair)
by dkim73 5/10/2011 7:48:46 AM(UTC)
GE Profile Dishwasher will not drain completely (Dishwasher Repair)
by michellemb 1/5/2011 8:05:52 AM(UTC)
Maytag dishwasher will not drain (Dishwasher Repair)
by rod.barnes 12/15/2010 3:46:38 PM(UTC)
GE QuietPower Dishwasher will not drain 100% (Dishwasher Repair)
by kjac3585 10/18/2010 5:48:36 PM(UTC)
White Westinghouse Dishwasher will not drain (Dishwasher Repair)
by Guardian305 10/1/2010 11:38:11 AM(UTC)
Maytag Dishwasher will not drain completely! (Dishwasher Repair)
by dahilife 8/9/2010 8:43:50 AM(UTC)
GE Profile dishwasher will not drain (Dishwasher Repair)
by pajero378 7/30/2010 11:10:20 AM(UTC)
GR p Profile dishwasher will not drain (Dishwasher Repair)
by parardise1 6/23/2010 6:17:52 AM(UTC)
dishwasher will not drain (drain pump is new) (Dishwasher Repair)
by jkda1975 4/6/2010 11:28:41 AM(UTC)
by dstoner 1/30/2010 6:20:05 AM(UTC)
Frigidaire Dishwasher will not drain....... (Dishwasher Repair)
Belarus FDAR 1/9/2010 1:16:11 PM(UTC)
by mekmak 1/8/2010 7:04:44 AM(UTC)
by Stardell 12/10/2009 8:21:02 PM(UTC)
