Stardell
#1 Posted : Thursday, December 10, 2009 8:21:02 PM(UTC)
Stardell
DW works fine but will not drain. The only hose I can see under the sink looks like the water line. Nothing connects to the disposal,other than the drain from the sink. I cannot locate a diagram for the Jenn-Air JDB6510 to do any closer examination. Side note: the outside temperature has been between 12 and 30 degrees. Help.
#2 Posted : Saturday, December 12, 2009 3:14:02 AM(UTC)
Here are parts for your unit re:AWP
Pump & motor replacement parts for JENN-AIR JDB6510AWP Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/m...ibrary/docs/16022580.pdf
First you have to determine is if it is trying to drain.
If yes then it is probably a drain line or a pump problem.
If no then it is either a timer or a motor problem.
Am not sure why you mentioned the outside temperature?
olypm
#3 Posted : Monday, December 21, 2009 11:05:13 AM(UTC)
olypm
Do you have a Johnson T value air vent which vents to outside? It might have froze solid. I suggest this because, (a) you don't see a drain line, Johnson T values drain into a copper pipe that goes into the wall behind the DW. You should see a vent on your outside wall kind of behind and above the dishwasher. (b) If the P trap in the Johnson T value froze, it blocks the DW from draining, but everything else works fine.
There are also vents that vent into the wall cavity. I don't know if these are code or not, but I've seen them (Home Depot).
I figured this was the problem on my DW by taking it out and running a cycle with it draining into the sink just to make sure the DW was working okay. Next I blew air into the drain pipe and it was plugged. I waited a couple days and it thawed and I put everything back. Oh, I used a shopvac to drain the standing water in the DW first.
Johnson T's are bad, bad, bad. They were big in the 1990's with granite kitchens. If that is what you have, consider retrofitting around it (into the disposer, etc.).
Hope this helps,
Jeff
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Dishwasher will not drain at end of cycle ... (Dishwasher Repair)
by dkim73 5/10/2011 7:48:46 AM(UTC)
GE Profile Dishwasher will not drain completely (Dishwasher Repair)
by michellemb 1/5/2011 8:05:52 AM(UTC)
Maytag dishwasher will not drain (Dishwasher Repair)
by rod.barnes 12/15/2010 3:46:38 PM(UTC)
GE QuietPower Dishwasher will not drain 100% (Dishwasher Repair)
by kjac3585 10/18/2010 5:48:36 PM(UTC)
White Westinghouse Dishwasher will not drain (Dishwasher Repair)
by Guardian305 10/1/2010 11:38:11 AM(UTC)
Maytag Dishwasher will not drain completely! (Dishwasher Repair)
by dahilife 8/9/2010 8:43:50 AM(UTC)
GE Profile dishwasher will not drain (Dishwasher Repair)
by pajero378 7/30/2010 11:10:20 AM(UTC)
GR p Profile dishwasher will not drain (Dishwasher Repair)
by parardise1 6/23/2010 6:17:52 AM(UTC)
dishwasher will not drain (drain pump is new) (Dishwasher Repair)
by jkda1975 4/6/2010 11:28:41 AM(UTC)
by dstoner 1/30/2010 6:20:05 AM(UTC)
Frigidaire Dishwasher will not drain....... (Dishwasher Repair)
by FDAR 1/9/2010 1:16:11 PM(UTC)
by mekmak 1/8/2010 7:04:44 AM(UTC)
by brussdogg79 12/1/2009 4:40:55 AM(UTC)
